Hi Guys,
Something strange going on, i can only assume i have done something wrong (or is the incorrect data being send by the plugin?) but got my LightwaveRF switch linked into openHab 1.8.3 last night and the “on” message is working fine. However then i try to turn it off, nothing happens. i can see in the log (below) everything looks ok, its sending the same message just with the state=‘OFF’ and not ‘ON’, just nothing happens. The “ON” works every time.
ON debug:
2016-09-03 12:12:59.709 [DEBUG] [.rfxcom.internal.RFXComBinding] - Received command: Light1 ON
2016-09-03 12:12:59.711 [DEBUG] [.rfxcom.internal.RFXComBinding] - Received command (item=‘Light1’, state=‘ON’, class=‘class org.openhab.core.library.types.OnOffType’)
2016-09-03 12:12:59.712 [DEBUG] [.rfxcom.internal.RFXComBinding] - Transmitting data: 0A14001B30271201010000
2016-09-03 12:13:00.423 [DEBUG] [.b.r.internal.RFXComConnection] - Data received:
Raw data = 0402011B00
- Packet type = TRANSMITTER_MESSAGE
- Seq number = 27
- Sub type = UNKNOWN
- Response = ACK
2016-09-03 12:13:00.425 [DEBUG] [rfxcom.internal.ResultRegistry] - Transmitter response received:
Raw data = 0402011B00 - Packet type = TRANSMITTER_MESSAGE
- Seq number = 27
- Response = ACK
2016-09-03 12:13:00.426 [DEBUG] [.rfxcom.internal.RFXComBinding] - Command succesfully transmitted, ‘ACK’ received
OFF debug:
2016-09-03 12:14:37.012 [DEBUG] [.rfxcom.internal.RFXComBinding] - Received command: Light1 OFF
2016-09-03 12:14:37.014 [DEBUG] [.rfxcom.internal.RFXComBinding] - Received command (item=‘Light1’, state=‘OFF’, class=‘class org.openhab.core.library.types.OnOffType’)
2016-09-03 12:14:37.016 [DEBUG] [.rfxcom.internal.RFXComBinding] - Transmitting data: 0A14001C30271201000000
2016-09-03 12:14:37.726 [DEBUG] [.b.r.internal.RFXComConnection] - Data received:
Raw data = 0402011C00
- Seq number = 28
- Response = ACK
2016-09-03 12:14:37.729 [DEBUG] [rfxcom.internal.ResultRegistry] - Transmitter response received:
Raw data = 0402011C00 - Packet type = TRANSMITTER_MESSAGE
- Seq number = 28
- Response = ACK
2016-09-03 12:14:37.731 [DEBUG] [.rfxcom.internal.RFXComBinding] - Command succesfully transmitted, ‘ACK’ received
If anyone can help, it would be much appreciated.
