Hi there,
i’m searching for a correct “button/switch/” in habpanel to create a similar “blind control” like this on (automated item created by paperUI).
any suggestions? thanks in advantage
Tom
Hi there,
Tom
thanks for your help … cause im not familiar to handle the .json-Files, i’ve seen that your widget is also available via widget gallery (for beginners: go to Habpanel; edit your panel; click on “plus”-symbol in the upper right corner; select “more”; find the “Rollershutter / blinds widget” or as an alternative the “Blinds”-Widget from A.Popov and customized it.
Thanks for your help!
