Hi
Since I have changed to OH2 my rollershutters make problem:
I have disabled the switch in sitemap and also disabled my rollershutter rule.
Only with the presence of my rollershutter items, the problem is there:
items:
Also with my wallswitch (KNX) the rollershutter only steps. I have to push the switch many times until the rollershutter moves. And when its moves I’m not able to stop…
When I remove the rollershutter item from my items file, it works like in OH1.8.
I have no idea.
I don’t know the Merten actuator, but normally, shutter actuators have these GAs, perhaps some are locked, but you should be able to unlock certain Features in the ETS within the programming of the actuator.
As explained in my above post, you should have two options in a shutter actuator: Kurzzeitbetrieb and Langzeitbetrieb. short term operation just gives the shutter a short spin of the slat (=Lamelle) in direction, which is defined by the rocker switch (Wippenschalter): one side is up or the other is down. Long term operation then moves the shutter up and down at once.
Did you configure your KNX-Installation yourself, or did it your electrician? I think, you have to be sure, your KNX-Installation works for itself, before adding the configuration of openHAB.
I don’t think configuring “Bewegung” and “Stop/Schritt” on the same GA is a good idea… In my case “Bewegung” (movement) is one GA bound to the long press of a directional switch and “Stop/Schritt” (stop/tilt) is on the short press of the same directional switch…
Even if the actuator knew what to do with these conflicting informations, i would guess it would stop right away and not move the rollershutter to its end-position…
Thanks guys. Exactly that was the problem. OH1.x doesn’t care. In daily use with KNX Switches it was OK. One push up for moving and a second push for stop.
But now it works fine.
has in fact no response address of the shutter position.
Just Langzeit-/ Kurzzeit Betrieb.
When i give the Rollershutter Item the Langzeit Address, i can move it, but I can´t stop it…
When i give it the Kurzzeit Address it just moves in tiny steps…
