Hi @chris,
just to be sure: did you get my e-mail?
Regards
Christoph
I’ve found it - it ended up in Spam, but I’ve managed to retrieve it…
Great!
I think there’s something funny going on with your rules, or something…
Looking at the above, you can see that you send a command (actually 2 commands!) to set the heating to 24deg. We then see the device wake up - it sends the battery report and setpoint. The setpoint is current 18deg, and we see this correctly reflected with the state update. 34ms later, you are setting the state back to 18 deg. We then see the setpoint commands being set - initially to 24 deg, then shortly after (ie 150ms later) it’s set back to 18 deg due to the last command you sent.
Given this command came only a few ms after the state was updated, I guess somewhere there is a rule that is sending this update - either that, or you’re real quick sending updates.
