I switched from xiaomi binding to zigbee2mqtt.
Now there is a change of the value i get back from the xiaomi motion sensor, with the binding I get the value ON or OFF, and with the zigbee2mqtt i get the value true ore false.
Now i get an error by a rule i had before, but the rule is working.
i get the following error:
2018-06-28 06:56:16.707 [vent.ItemStateChangedEvent] - Motion_FF_Bed changed from false to true
java.lang.RuntimeException: {"error":"partial write: field type conflict: input field \"value\" on measurement \"Motion_FF_Bed\" is type string, already exists as type float dropped=1"}
and this is my rule (is changed to work with true and false):
var Timer timer = null
rule "Licht Schlafzimmer bei Bewegung Einschalten"
Item Motion_FF_Bed changed to "true"
if(timer === null && flagItemsunset.state == ON) {
logInfo("FILE", "Setting to ON and creating timer")
Light_FF_Bed_Ceiling.sendCommand(ON)
timer = createTimer(now.plusMinutes(2), [|
logInfo("FILE", "Timer expired and setting to OFF")
Motion_FF_Bed.postUpdate("false")
Light_FF_Bed_Ceiling.sendCommand(OFF)
timer = null
} else {
logInfo("FILE", "Timer rescheduled")
timer.reschedule(now.plusMinutes(2))
that was the previous rule :
Item Motion_FF_Bed received update ON
Motion_FF_Bed.postUpdate(OFF)
timer = null
} else {
With the On and OFF value i never had these error.
This is to do with persistence.
OH is trying to save the state to the DB as a string but the DB field is set to as float
Access your DB and change the type of the field or remove the table for that item and OH will recreate it with a string field.
i have the same error after the drop measeurement itemname.
i have no experience with influxdb
can anyone help me which commands I have to enter?
now i get more details about the error:
2018-06-28 17:10:22.873 [vent.ItemStateChangedEvent] - Motion_FF_Bed changed from false to true
2018-06-28 17:10:22.896 [INFO ] [.eclipse.smarthome.model.script.FILE] - Timer rescheduled
2018-06-28 17:10:22.908 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Licht Schlafzimmer bei Bewegung Einschalten': cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.reschedule(org.joda.time.base.AbstractInstant) on null
2018-06-28 17:10:22.972 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
at org.influxdb.impl.InfluxDBErrorHandler.handleError(InfluxDBErrorHandler.java:19) [232:org.openhab.persistence.influxdb:1.12.0]
at retrofit.RestAdapter$RestHandler.invoke(RestAdapter.java:242) [232:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.$Proxy168.writePoints(Unknown Source) [232:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:151) [232:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:171) [232:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:144) [232:org.openhab.persistence.influxdb:1.12.0]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
I have also messed around with different item types and would like to drop all data from my influxDB openhab_db database (without deleting the openhab_db database itself).
How to expand your drop statement above to all measurements and all series?
