- Platform information:
- Hardware: Raspberry Pi3
- OS: openhabian buster (actual stable)
- Java Runtime Environment: I think Zulu, which was auto installed
- openHAB version: 2.4
I have multiple Sonoff basics which communicate over mqtt and mosquitto. I did the complete configuration in paperUI, what works absolutely correct. I can turn the switches and read the sensor data plugged in the Sonoffs.
For the role management I installed the experimental rule engine. There I created two rules for my tank-light. It should turn the light on at 8am and turn off at 8pm (Fixed time - send command - ON / OFF). After creating I tested the rule with the “play” button and it works.
But when the time comes, nothing happens. If I toggle the switch manually at 8.01pm the light turns on/off. So, connection is there. Now I go into the rule management and press the play button, nothing happens. Then i open the rule and click on a gear (eg for fixed time) and save again (I changed nothing!). After this the rule worked again on pressing the play-button.
I didn’t know why this happens. Any ideas?
Thank you
