hi all
I have set up the following rule for controlling a heat resistance: ought to be on when fotovoltaic production is bigger than whole home comsumption.
the rule is the following:
Blockquote
rule “stufetta bagno”
Item ProduzioneFotovoltaico_Power changed or
Item gconsumotot changed
var Number energyDiff = (ProduzioneFotovoltaico_Power.state as Number) - (gconsumotot.state as Number)
if (energyDiff <= 0) {
PresaCinema.SendCommand(ON)
else if (energyDiff >= -5) {
PresaCinema.SendCommand(OFF)
Code fences would make this a little easier to read.
postUpdate(energyDiff)
Make the following changes:
Use standard double quotes ", not “ and ”
Should be energyDiff.intValue
You need to specify the item you want to update. For example: YourItem.postUpdate(energyDiff).
