[SOLVED] RULE QUESTION: After sunset do this
Hey guys,
I have been playing with the astro binding and sunset events.
Im trying to create a rule that does this:
rule "Do stuff on button press if its after sunset"
        Item alarm_switch received command ON
        if sunset.started {
        do this
        } else {
        do this
I have tried using formulas others have stated but no luck.
Thanks.
Assuming this is pseudocode since the syntax is pretty wrong.
See Design Pattern: Time Of Day for a comprehensive way to centralize all of you time calculations.
Even if you don’t adopt the DP, it will show how to do all the operations with Astro trigger channels and time comparisons you need.
Yeh it is indeed pseudocode. Thanks for the link.
EDIT. This might be a bit beyond me :confused:
Basically you need three rules and another item
The item:
Switch IsItDark
The rules:
rule "Sunset"
    Channel 'astro:sun:home:set#event' triggered START
    IsItDark.postUpdate(ON)
rule "Sunrise"
    Channel 'astro:sun:home:rise#event' triggered START
    IsItDark.postUpdate(OFF)
    if (IsItDark.state == ON) {
        // do this
    } else {
        // do that
It may be for now.
My advice.
Read the DP and then copy the code. I don’t mean copy and paste. I mean write the code yourself, line by line.
I my experience this is still the best way to understand code.
Write it or copy it. Understand it. When you copy it line by line your understanding of it will come.
Good luck
Yes, thanks I will do that. I appreciate the help and advice. Its like I can picture the things that need to happen but I struggle with the details.
