[SOLVED] Rule startup issue - The method toDateMidnight() from the type DateTime is deprecated
I have a rule that brings up an error message when system is started. any idea what goes wrong…seems to work but would love to have as little errors in my log files as possible. Thanks to the experts for a quick check.
2018-04-06 21:58:59.584 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'tempminmax.rules', using it anyway:
rule "Update TempOutside Min&Max"
Item MyTemp_Outside received update
    var Number Xtemp
    if (MyTemp_Outside.state instanceof DecimalType) {
            Xtemp = (MyTemp_Outside.minimumSince(now.toDateMidnight, "rrd4j").state as DecimalType)
            Xtemp = (Math::round(Xtemp.floatValue*10.0)/10.0)
            postUpdate(MyTempOutMIN, Xtemp)
            Xtemp = MyTemp_Outside.maximumSince(now.toDateMidnight, "rrd4j").state as DecimalType
            postUpdate(MyTempOutMAX, Xtemp)
thanks a lot…
2018-04-06 22:19:54.956 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘tempminmax.rules’
That fixed it -> You should use now.withTimeAtStartOfDay
