[SOLVED] Rule syntax error?
Hi All
I see this error in the following rule, it doesnt like ‘garage’
21:52:39.406 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Blue Iris Motion Detection Alert - Garage': The name 'Garage' cannot be resolved to an item or type; line 145, column 32, length 6
rule "Blue Iris Motion Detection Alert - Garage"
    Item Motion_Garage received command
     if(Kris_MobileAP.state != Garage || Jodie_MobileAP.state != Garage){
         logInfo("Blue Iris", "There is motion in the Garage")
           Echo_Living_Room_TTS.sendCommand('There is motion in the Garage')
           Echo_Garage_TTS.sendCommand('The police have been called')
        sendBroadcastNotification("There is motion in the Garage")
Garage is a valid state…
openhab> smarthome:status Kris_MobileAP
UNDEF
openhab>
Not sure what I;'m doing wrong. Any suggestions?
Thanks!
You need to use quotes on the “Garage” state, it’s a custom string.
So, change:
if(Kris_MobileAP.state != Garage && Jodie_MobileAP.state != Garage){
to
if(Kris_MobileAP.state != “Garage” && Jodie_MobileAP.state != “Garage”){
Ah! So only ON, OFF, OPEN, CLOSED etc can be used without quotes. Thanks Alpoy!
Yepp :slight_smile:
Yes, these are commands defined in the DSL
A color item accepts ON, OFF INCREASE, DECREASE
Contact - OPEN, CLOSED
Dimmer same as color
Player - PLAY, PAUSE, REWIND, FASTFORWARD, NEXT, PREVIOUS
Rollershutter - UP, DOWN, STOP, MOVE
Switch - ON, OFF
See: https://www.openhab.org/docs/configuration/items.html#type
