hey guys. I’m trying to use the hue motion sensors temperature sensor but they ant accurate at all I’ve got one that’s 3 degrees c out so im trying make a rule that will add or subtract and post the correct temp to a dummy item.
what ive got so far.
Items
Switch Lounge_Motion "Lounge Motion Sensor" (gMotion) {channel="hue:0107:00178829a0c5:44:presence"}
Number:Temperature Lounge_Hue_Temp "Temperature [%.1f °C]" <temperature> {channel="hue:0302:00178829a0c5:43:temperature"}
Number:Temperature Lounge_Hue_Temp_Offset "Temperature [%.1f °C]"
Switch Rileys_Motion "Rileys Room Motion Sensor" (gMotion) {channel="hue:0107:00178829a0c5:38:presence"}
Number:Temperature Rileys_Hue_Temp "Temperature [%.1f °C]" <temperature> {channel="hue:0302:00178829a0c5:37:temperature"}
Number:Temperature Rileys_Hue_Temp_Offset "Temperature [%.1f °C]" <temperature>
rule
rule "temperature update Lounge"
Item Lounge_Hue_Temp changed or
Item Temp_Test changed
Lounge_Hue_Temp_Offset.sendCommand(Lounge_Hue_Temp.state + 10|"°C")
rule "temperature update Rileys Room"
Item Rileys_Hue_Temp changed or
Rileys_Hue_Temp_Offset.sendCommand(Rileys_Hue_Temp.state + 10|"°C")
error in the log
2018-12-27 22:26:46.448 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Test.rules'
2018-12-27 22:26:48.467 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'Test.rules'
2018-12-27 22:26:55.941 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'temperature update Lounge': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_plus(java.lang.Object,java.lang.String) on instance: null
2018-12-27 22:26:55.941 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'temperature update Rileys Room': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_plus(java.lang.Object,java.lang.String) on instance: null
2018-12-27 22:26:56.158 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'temperature update Lounge': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_plus(java.lang.Object,java.lang.String) on instance: null
2018-12-27 22:26:56.158 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'temperature update Rileys Room': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_plus(java.lang.Object,java.lang.String) on instance: null
