I trying to get a rule correct which will power cycle a device which has gone offline.I’m having trouble with the logic and hoping folks here can point me in the right direction. My rule attempt is below.
Some more info:
One of my old Sonos players goes offline every week or two and I’d like to automatically reboot it. I have the state of the device being tracked successfully using the network binding. I also have a z-wave appliance module in place to turn power off and on again.
My basic logic:
Detect change in online state
if offline & not currently rebooting (give the device time to boot)
Turn off, set timer to turn on and set rebooting flag
If online
Clear timers and flags
var Timer powerCycleTime = null
var Timer delayPowerCycle = null
rule "Sonos online test"
Item Sonos_ZP3_online changed
if (Sonos_ZP3_online.state === OFF && flag_sonosRebooting === OFF){
Switch_LR_Sonos.sendCommand(OFF)
flag_sonosRebooting.sendCommand(ON)
powerCycleTime = createTimer(now.plusSeconds(10) [|
Switch_LR_Sonos.sendCommand(ON)
delayPowerCycle = createTimer(now.plusMinutes(5) [|
flag_sonosRebooting.sendCommand(OFF)
} else if (Sonos_ZP3_online.state === ON) {
Associated things:
Switch Sonos_ZP3_online "Sonos LR online" (Networking) { channel="network:pingdevice:192_168_1_92:online" }
Switch flag_sonosRebooting "Sonos is rebooting" (HA_Flags)
Switch Switch_LR_Sonos "LR Sonos [%s]" (FF_Living) [ "Switchable" ] {channel="zwave:device:512:node73:switch_binary"} /* Sonos Control */
Platform information:
Hardware: RaspberryPi
OS: OpenHabian
Java Runtime Environment: (Whatever is on OpenHabian by default)
I use this rule for iPhone presents to turn on/off a light when not home. I think if you use the same logic it will work for your Sonos. You can try with changing the names to match and setting the expire time to suit your needs, maybe 5 min for your situation. Note the items are grouped and there is an expire timer (where you set the 5min) with command off. Also in things I use a retry, timeout, and refresh to make sure the connection is valid before starting the rule.
Rule:
rule "start gPresent on system start"
System started
Present.sendCommand(OFF)
rule "gPresent updated, at least one change of state"
Item gPresent received update
if(gPresent.state == ON && Present.state != ON) {
Present_Timer.postUpdate(OFF) // cancel the timer if necessary
Present.sendCommand(ON)
// no answer from Sonos and timer is not yet ticking (otherwise endless loop)
else if(gPresent.state == OFF && Present.state != OFF && Present_Timer.state != ON) {
Present_Timer.sendCommand(ON) // start the timer
rule "Present_Timer expired"
Item Present_Timer received command OFF
Items:
Group:Switch:AND(OFF,ON) gPresent <present>
Switch Present "Phone is home" <present> // Your Sonos is online
Switch Present_Timer { expire="20m, command=OFF" } // Timer for power cycle of Sonos
Switch MyDevice <network> (gPresent) { channel="network:pingdevice:SiPhone:online" }
Thanks Harry, that did the trick. In an earlier iteration I was checking for the timers to be null and needed the identity operator. When I switched the logic I never changed it back to the equality operator.
Thanks so much @H102, I ended up reworking my rules to follow a model more like yours. I wasn’t aware of the Expire binding and found it worked better than the timers for my case. Thanks also for recommending the retries on the ping.
Here are my corrected and functioning rules and related items.
// Assume Sonos online at system start
rule "Set Sonos rebooting off on system start"
System started
Sonos_ZP3_online.postUpdate(ON)
// Sonos state has changed, see if reboot needed
Item Sonos_ZP3_online received update
if(Sonos_ZP3_online.state == OFF && sonos_rebootTimer.state != ON) {
sonos_rebootTimer.sendCommand(ON) // start the timer
else if(Sonos_ZP3_online.state == ON) {
sonos_rebootTimer.postUpdate(OFF) // cancel the timer if necessary
Items:
Switch Switch_LR_Sonos "LR Sonos [%s]" (FF_Living) [ "Switchable" ] {channel="zwave:device:512:node73:switch_binary", expire="30s,command=ON"} // Z-wave switch only stays off for 30 sec
Switch Sonos_ZP3_online "Sonos LR online" (Networking) { channel="network:pingdevice:192_168_1_92:online" } // Thing configured in paper UI with 3 retries
Switch sonos_rebootTimer "Sonos rebooting" { expire="5m, command=OFF" } // Flag with timer to allow Sonos time to start
