I want to create a crontab-Rule that stores the sunset - sunrise time in a variable.
Then I want to rotate this value every day to get the difference for last 7days…
My Items:
Number Daylight1 "Daylight-1"
Number Daylight2 "Daylight-2"
Number Daylight3 "Daylight-3"
Number Daylight4 "Daylight-4"
Number Daylight5 "Daylight-5"
Number Daylight6 "Daylight-6"
Number Daylight7 "Daylight-7"
DateTime Sunrise_Time "Sunrise [%1$tH:%1$tM]" { channel="astro:sun:home:rise#start" }
DateTime Sunset_Time "Sunset [%1$tH:%1$tM]" { channel="astro:sun:home:set#start" }
So each day at 10:00 i want this update script to rotate Daylight.
Day-1 -> Day-2
Day-2 -> Day-3
etc…
Rule
rule "Astro Rules"
Time cron "0 0 10 * * ?"
Can someone please advise. Format of the “Daylight1->7” should be in minutes calculated with Sunset-Sunrise…
Daylight1 = (new DateTime(Sunset_Time.state.toString).millis - new DateTime(Sunrise_Time.state.toString).millis) / 1000
But I get this in the log: [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule ‘Astro Rules’: An error occurred during the script execution: Cannot assign a value in null context.
Ok let’s see:
From the Astro binding you have daylight:duration channel - Use that!
You will need to create 7 Number items, the first one linked to the channel and the other with no binding
The rule will be like this:
itemDay1 will update every day at 00:00:30 (Astro binding calculation time) with the daylight duration
the rule:
rule "rotate daylight"
Time cron "15 0 0 ? * * *" // Every day at 00:00:15 (BEFORE THE ASTRO UPDATE)
itemDay7.postUpdate(itemDay6.state)
itemDay6.postUpdate(itemDay5.state)
itemDay5.postUpdate(itemDay4.state)
itemDay4.postUpdate(itemDay3.state)
itemDay3.postUpdate(itemDay2.state)
itemDay2.postUpdate(itemDay1.state)
Note that the durations will be in seconds BUT you can display them in the sitemap as minutes by using the UoM
Yes because it goes from Sunrise:Start to Sunset:End (The sun takes time to rise and set and you have to take that into consideration). Astronomers define day light at when the sun is visible (Even a tiny little bit of it!!)
