I searched the Forum and find this issue, but there had been allways different Script-Errors and I didn’t found a solution.
Its a rule for the washing machine. It works fine, but sometimes it throws an error in the Log:
openhab.log:
2019-02-18 12:52:10.612 [INFO ] [model.script.5_Fenster_Heizung.rules] - EG-Twins: Fenster geschlossen, Temperatur 5 °C wieder hergestellt
2019-02-18 12:52:25.180 [INFO ] [veClimateControlScheduleCommandClass] - NODE 25 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2019-02-18 12:52:53.186 [INFO ] [veClimateControlScheduleCommandClass] - NODE 15 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2019-02-18 12:52:56.831 [INFO ] [.model.script.UG_Waschmaschine.rules] - Sende: 2.085639404990511
2019-02-18 12:52:56.836 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'UG Waschmaschine fertig': An error occurred during the script execution: null
2019-02-18 12:53:41.857 [INFO ] [veClimateControlScheduleCommandClass] - NODE 26 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2019-02-18 12:53:56.828 [INFO ] [.model.script.UG_Waschmaschine.rules] - Sende: 2.099385238252456
2019-02-18 12:54:28.732 [INFO ] [veClimateControlScheduleCommandClass] - NODE 5 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2019-02-18 12:54:49.731 [INFO ] [veClimateControlScheduleCommandClass] - NODE 14 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2019-02-18 12:54:56.858 [INFO ] [.model.script.UG_Waschmaschine.rules] - Sende: 2.105264519848996
2019-02-18 12:55:03.959 [INFO ] [veClimateControlScheduleCommandClass] - NODE 27 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
event-log time of error:
2019-02-18 12:52:56.831 [vent.ItemStateChangedEvent] - UG_Waschmaschine_Plug_Watt changed from 2.251 to 2.116
2019-02-18 12:52:56.832 [ome.event.ItemCommandEvent] - Item 'UG_Waschmaschine_Plug_Watt_5Min' received command 2.085639701687717
2019-02-18 12:52:56.834 [ome.event.ItemCommandEvent] - Item 'UG_Waschmaschine_Plug_Watt_10Min' received command 2.039410909602702
2019-02-18 12:52:56.835 [vent.ItemStateChangedEvent] - UG_Waschmaschine_Plug_Watt_5Min changed from 2.047702734365788 to 2.085639998382924
2019-02-18 12:52:56.837 [vent.ItemStateChangedEvent] - UG_Waschmaschine_Plug_Watt_5Min changed from 2.085639998382924 to 2.085639701687717
2019-02-18 12:52:56.837 [vent.ItemStateChangedEvent] - UG_Waschmaschine_Plug_Watt_10Min changed from 2.032033465381962 to 2.039411134619455
2019-02-18 12:52:56.837 [vent.ItemStateChangedEvent] - UG_Waschmaschine_Plug_Watt_10Min changed from 2.039411134619455 to 2.039410909602702
The Rule caused the error:
rule "UG Waschmaschine fertig"
Item UG_Waschmaschine_Plug_Watt_10Min changed
val Number currentSecond = now.getSecondOfMinute + 1
val MessageList = newArrayList('BLA1', 'BLA2', 'BLA3')
val Number maxMessages = 3.0
if (UG_Waschmaschine_Plug_Watt_10Min.state < 7.0 && UG_WaschmaschineAn.state == ON) {
logInfo("UG_Waschmaschine.rules", "Fertig: " + UG_Waschmaschine_Plug_Watt_10Min.state)
UG_WaschmaschineAn.sendCommand(OFF)
UG_WaschmaschineAn.postUpdate(OFF)
sendTelegram("Jens","Waschmaschine fertig")
var int chosenMessage = (Math::floor((currentSecond.floatValue+30/maxMessages.floatValue) * maxMessages.floatValue / 60.0 )).intValue
// var String Nachricht = MessageList.get(chosenMessage)
sendTelegram("Jens", "Sekunde: "+currentSecond+"\n--- Max: "+maxMessages+"\n---Gewählt: "+chosenMessage+"\n---Text: "+"Nachricht")
Curious that the Rule is triggered twice to recalculate 5Min-Usage and 10-Min-Usage (if looking in Log, one command received, two Updates):
rule "UG Waschmaschine Durchschnittsverbrauch"
Item UG_Waschmaschine_Plug_Watt received update
logInfo("UG_Waschmaschine.rules", "Sende: " + UG_Waschmaschine_Plug_Watt.averageSince(now.minusMinutes(5)).toString)
UG_Waschmaschine_Plug_Watt_5Min.sendCommand(UG_Waschmaschine_Plug_Watt.averageSince(now.minusMinutes(5)))
UG_Waschmaschine_Plug_Watt_5Min.postUpdate(UG_Waschmaschine_Plug_Watt.averageSince(now.minusMinutes(5)))
UG_Waschmaschine_Plug_Watt_10Min.sendCommand(UG_Waschmaschine_Plug_Watt.averageSince(now.minusMinutes(10)))
UG_Waschmaschine_Plug_Watt_10Min.postUpdate(UG_Waschmaschine_Plug_Watt.averageSince(now.minusMinutes(10)))
The Rule itself works, but I want to get rid of this errors.
Somebody has got an idea?
