I have the Harmony item file
String HarmonyHubWK "Action [%s]" { hannel="harmonyhub:hub:HarmonyHub:currentActivity"} String HarmonyHubWKSamsung "Samsung" { channel="harmonyhub:device:HarmonyHub:57698079:buttonPress" }
sitemap
Switch item=HarmonyHubWKSamsung mappings=["PowerOff"="PowerOff","PowerOn"="PowerOn"]
rules
rule "beneden uit"
Item goodnight received update
Echo_Living_Room_TTS.sendCommand('Goodnight Peter and Desiree, sleep well')
sendCommand(HarmonyHubWKSamsung, PowerOff)
This does not work, it works at the sitemap, it does not work in the rules
please help
vzorglub
(Vincent Regaud)
October 5, 2018, 4:31pm
2
I am sorry, what does that mean?
Ah,
when i press the buttons on the site map - the television goes on/of
when the rule triggers is does not work
vzorglub
(Vincent Regaud)
October 5, 2018, 4:43pm
4
Can you show the logs when you press the button and when the rule triggers, please?
Try:
sendCommand(HarmonyHubWKSamsung, "PowerOff")
The Item
is a String so likely expects a StringType command.
If you need further help you may want to post log snippet when the rule runs.
vzorglub
(Vincent Regaud)
October 5, 2018, 6:11pm
6
Or better:
HarmonyHubWKSamsung.sendCommand("PowerOff")
