It’s quite difficult to interpret the rule without code fencing, without indents etc.
rule “KWLoad Logging rules”
Item InstPWR changed or
Item KWloadSetpoint changed
//logInfo(“system load.rules”, "cpu load changed " + systeminfo_computer_u2_cpu_load.state.toString )
// if valid ( Not NULL)
// if (KWloadSetpoint.state != NULL) {
// true null/undef check
//if (triggeringItem.state == NULL || triggeringItem.state == UNDEF) return
logInfo("Power Usage Trig not NULL ")
if ((InstPWR.state as DecimalType) > (KWloadSetpoint.state as DecimalType)) {
// we have hit a set point for presence ?
postUpdate(PowerUseageTrig,ON)
// toggle ON/OFF for 5m presence
logInfo("Power Usage Trig ON " + PowerUseageTrig.state.toString )
//main log
if (KWModeSW.state ==1 || KWModeSW.state ==3) {
postUpdate(MainLog, "W Useage : " + InstPWR.state.toString) } //$Log
if (KWModeSW.state ==2 || KWModeSW.state ==3) {
SendTelegram.postUpdate("W Useage : " + InstPWR.state.toString) } //VTelegram
else
// needs small delay
postUpdate(PowerUseageTrig,OFF)
Most of your diagnostic aids are commented out.
If my interpretation of your rule is correct and this isn’t commented out - logInfo("Power Usage Trig not NULL ")
it’s faulty syntax. logInfo() requires at least two parameters.
VSCode with openHAB extension is a useful tool for catching basic syntax errors.
I find this web ui awkward/not helpful to get the indent to work, to appears to indent the first line and thats it.
Also unable to reply inline to individual comments just at the end ?
I was commenting out script that were not ready to be used yet, and proposed new additions which are no use with unhelpful errors of index 1, size 1 ,how would that relate to line 14 ?
I assumed it was stalling on the use of !=NULL or a variation of this test ie NOT NULL or null
VScode is installed with openHAB extension , yet says nothing
If you highlight part of a post, a “quote” popup appears. Is that what you mean?
I don’t understand your question.
Yes, it’s an unhelpful error message.
Validation is done at openHAB itself. If you use VSCode without a “live link” to your openHAB, you do not get full validation.
When that is working, VSCode will highlight an attempt to use logInfo() with only one parameter.
