[SOLVED] Rules: No trigger from item at all (only time cron triggers are working)
:sleepy: it doesn’t solve the problem. It only delayed it bevor the rules stopps working.
What I tried yesterday:
  1. sudo systemctl stop openhab2.service
  2. remove all file in openhab2-userdata\jsondb\
  3. sudo systemctl start openhab2.service
  4. after a will the file openhab2-userdata\jsondb\org.eclipse.smarthome.config.discovery.DiscoveryResult.json occurs
  5. I add the to things from that file into homematic.things
    Thing HmIP-RCV-50       00041234ADFB23   "Homematic IP virtuelle Fernbedinung" @ "UG Technikraum" {
        Channels:
    Thing GATEWAY-EXTRAS-CCU   GWE00000000   "Homematic IP virtuelle Fernbedinung" @ "UG Technikraum" {
        Channels:
  6. sudo systemctl stop openhab2.service
  7. remove the file openhab2-userdata\jsondb\org.eclipse.smarthome.config.discovery.DiscoveryResult.json (so the jsondb is empty again)
  8. sudo systemctl start openhab2.service
After that all seems to work but only for about half an hour. I don’t know how to handle that problem.
Maybe it’s the right time to switch to the Next-Gen Rule engine.
Is it recommended to start with the version in the latest stable openhab release (2.5.1-2) or should I use a other version?
There’s nothing wrong with the “old” rules engine. It works for everyone else - the problem lies in your system.
You might circumvent it by redesigning your rules into a new form - or you might just reproduce the same design flaws.
From your description. you’ve got a rule(s) that is hogging rule execution threads.
I’m basing that on -
Cron triggered rules use threads from a different pool, so they’re independent.
Some kind of general system seizure would also be affecting events.log etc.
How many rules have you got? What can you temporarily comment out to reduce the suspects? Consider adding a logInfo() at the beginning of suspect rules to see when it starts, and another at the end to see when it exits.
Have you many modbus Items? Do you poll them fast? There is a change in default behaviour from v1 to v2 Modbus bindings that can hammer large configurations.
If you have rules triggering on modbus Item updates they can get hammered.
Yes, the version in the stable release is what you should use. For installing Jython, I recommend this bundle, which currently includes the helper libraries
I’d be curious about your results, but I doubt changing the rule engine will change anything. And if everything worked properly, there would still be an underlying issue that was not understood. Chances are it is a configuration issue, but there could also be a bug. At the same time though, the new rule engine will be what is used in OH 3.0, so now is a good time to migrate.
I have 36 modbus items with a refresh rate of 1 second. For a test I reduced the rate to 1 minute.
I have 235 rules. I also add to each rule a start and end logInfo, like
/* *** Debug *** */
val boolean ruleStartStopLogEn = true
rule D2N_OG_Bad_HK_Stellgroesse_Ist
	Item OG_Bad_HK_Stellgroesse_Ist changed
	var String sRuleName = ""
	if(ruleStartStopLogEn) { sRuleName = "D2N_OG_Bad_HK_Stellgroesse_Ist" }
	if(ruleStartStopLogEn) { logInfo("Rule", "Start: " + sRuleName) }
	if(ruleStartStopLogEn) { logInfo("Rule", "Ende: " + sRuleName) }
If that doesn’t work, I will migrate.
If it works
 would it be possible to migrate step by step? Is it possible to have rules in the next-gen rule engine and in the “old” one?
Absolutely
 it can be a phased migration! And I’ll bet that once you start, you’ll wish you had done it sooner!
That doesn’t seem like a “large” network for our purposes.
You might review for performance, but I doubt it is has a bearing here.
Unless you are triggering immense rules from updates! There are notes on rules design.
:smiley: I wished I had done it already
Yikes! This looks like it will work, but you could just create debug log entries and then change the logging level so that they will show in the log.
log:set DEBUG org.eclipse.smarthome.model.script
Create Log Entries in Rules
Also, SLF4J allows you to use parameterized logging, where the log entries that do not fit in the current logging level will not be processed. Meaning, you can put really complicated stuff in your debug log entry, but it won’t be processed when logging is set to INFO. However, the + operator will always be processed, so best not to use it.
/* *** Debug *** */
	val String sRuleName = "D2N_OG_Bad_HK_Stellgroesse_Ist"
	logDebug("Rule", "Start: {}", sRuleName)
	logDebug("Rule", "Ende: {}", sRuleName)
Some rules are working and others stopps. But in the log files I can’t see any reason.
An rule which has stopped is followed:
/* *** Debug *** */
rule OutTemp
	Item UG_TECHNIK_FW_Aussentemperatur_C   changed or
	Item Out_Temp_Quadra                    changed or
	Item Out_Temp_VonQuadraEnable           changed
	if(ruleStartStopLogEn) { sRuleName = "OutTemp" }
	if(ruleStartStopLogEn) { logInfo("Rule", "Start: {}", sRuleName) }
	var Number newTemp = -1
	// aktuelle Temperatur holen
	if (Out_Temp_VonQuadraEnable.state == ON)
		// Temperatur von Quadra abfragen
		if (Out_Temp_Quadra.state instanceof DecimalType)
			newTemp = Out_Temp_Quadra.state as DecimalType
	else
		// Temperatur von FernwÀrme abfragen
		if (UG_TECHNIK_FW_Aussentemperatur_C.state instanceof DecimalType)
			newTemp = UG_TECHNIK_FW_Aussentemperatur_C.state as DecimalType
	if (newTemp != -1)
		// auf eine gerade Nachkommastelle runden
		newTemp = Math::round(newTemp.floatValue/0.2)*0.2
		// alter Wert holen
		if (Out_Temp.state instanceof DecimalType)
			val Number oldTemp = Out_Temp.state as DecimalType
			var Number dif = 0.0
			// Differenz bilden
			if (newTemp > oldTemp)
				dif = newTemp - oldTemp
			else
				dif = oldTemp - newTemp
			if (dif >= 0.2) // nur bei Differenz >= 0.2
				Out_Temp.sendCommand(newTemp)
				logInfo("FernwÀrme", "Out_Temp aktualisiert. Wert <" + newTemp + "°C> diff <" + dif + ">")
		else
			// Update durchfĂŒhren
			logInfo("FernwÀrme", "Out_Temp konnte nicht gelesen werden, daher ohne Differenzbildung auf <" + newTemp + "°C> gesetzt")
	if(ruleStartStopLogEn) { logInfo("Rule", "Ende: {}", sRuleName) }
The rule is running for about 8 hours before stopping. 113 times.
2020-02-13 23:03:29.385 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:03:29.403 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:04:13.232 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:04:13.244 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:04:13.697 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'OutTemp': The name 'ruleStartStopLogEn' cannot be resolved to an item or type; line 152, column 5, length 18
2020-02-13 23:16:13.948 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:16:13.976 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:17:22.174 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:17:22.193 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:20:48.697 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:20:48.721 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:20:48.770 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:20:48.790 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:23:20.920 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:23:20.969 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:27:54.311 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:27:54.321 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:32:53.695 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:32:53.708 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:37:55.136 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:37:55.159 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:42:05.510 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:42:05.521 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:42:55.484 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:42:55.493 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:47:54.895 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:47:54.908 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:52:55.267 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:52:55.282 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:54:06.365 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:54:06.381 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-13 23:57:54.639 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-13 23:57:54.658 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:02:55.030 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:02:55.054 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:07:55.533 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:07:55.547 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:10:08.036 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:10:08.075 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:17:55.338 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:17:55.369 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:22:10.327 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:22:10.379 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:22:55.600 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:22:55.633 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:27:55.019 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:27:55.048 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:32:55.341 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:32:55.356 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:37:54.745 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:37:54.769 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:42:55.115 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:42:55.141 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:47:55.504 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:47:55.524 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:52:54.886 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:52:54.906 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 00:57:55.290 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 00:57:55.316 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:02:54.653 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:02:54.664 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:11:23.549 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:11:23.592 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:12:55.437 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:12:55.463 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:22:55.253 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:22:55.266 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:27:55.622 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:27:55.635 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:31:28.792 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:31:28.810 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:32:55.002 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:32:55.018 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:37:55.381 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:37:55.416 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:42:54.741 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:42:54.755 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:43:31.762 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:43:31.786 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:47:55.191 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:47:55.208 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:52:55.517 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:52:55.533 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 01:57:54.907 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 01:57:54.923 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:02:55.290 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:02:55.309 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:07:54.711 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:07:54.739 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:12:39.365 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:12:39.385 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:12:55.069 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:12:55.088 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:17:55.473 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:17:55.499 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:22:54.831 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:22:54.849 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:27:55.220 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:27:55.236 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:32:54.627 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:32:54.655 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:37:55.044 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:37:55.060 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:42:55.380 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:42:55.395 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:47:54.784 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:47:54.808 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:52:55.160 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:52:55.176 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 02:57:55.570 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 02:57:55.584 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:02:54.924 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:02:54.934 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:07:55.336 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:07:55.366 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:12:54.066 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:12:54.183 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:12:54.692 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:12:54.708 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:17:55.138 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:17:55.164 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:22:55.474 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:22:55.509 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:27:54.885 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:27:54.915 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:32:55.242 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:32:55.257 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:37:54.644 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:37:54.665 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:42:55.011 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:42:55.025 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:47:55.430 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:47:55.459 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:52:54.784 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:52:54.809 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:54:06.522 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:54:06.554 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 03:57:55.212 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 03:57:55.232 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:02:08.500 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:02:08.541 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:02:55.558 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:02:55.567 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:07:54.946 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:07:54.959 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:10:11.514 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:10:11.542 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:12:55.388 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:12:55.399 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:17:54.711 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:17:54.723 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:18:14.898 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:18:14.931 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:22:55.102 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:22:55.113 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:26:17.055 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:26:17.075 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:27:55.518 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:27:55.537 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:30:38.049 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:30:38.087 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:37:55.262 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:37:55.273 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:38:20.103 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:38:20.141 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:42:54.675 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:42:54.688 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:47:22.475 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:47:22.502 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:52:55.450 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:52:55.460 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 04:59:25.448 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 04:59:25.506 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:02:55.195 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:02:55.212 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:07:54.580 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:07:54.596 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:12:54.965 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:12:54.975 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:15:29.783 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:15:29.801 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:17:55.376 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:17:55.399 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:22:54.734 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:22:54.747 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:27:55.143 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:27:55.165 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:32:55.538 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:32:55.548 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:37:54.940 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:37:54.963 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:42:55.285 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:42:55.296 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:47:54.672 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:47:54.685 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:51:38.793 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:51:38.815 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:52:55.055 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:52:55.065 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 05:57:55.470 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 05:57:55.490 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:02:54.868 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:02:54.883 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:07:55.234 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:07:55.266 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:08:42.939 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:08:42.962 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:12:55.614 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:12:55.632 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:17:55.994 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:17:56.008 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:20:47.169 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:20:47.190 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:22:56.415 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:22:56.430 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:27:55.778 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:27:55.816 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:32:50.216 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:32:50.246 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:32:56.157 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:32:56.169 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:37:56.578 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:37:56.594 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:42:55.924 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:42:55.935 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
2020-02-14 06:44:53.223 [INFO ] [.eclipse.smarthome.model.script.Rule] - Start: OutTemp
2020-02-14 06:44:53.247 [INFO ] [.eclipse.smarthome.model.script.Rule] - Ende: OutTemp
the item changes doesn’t stop. One of the three items I picked out
2020-02-13 22:57:09.990 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from NULL to 3.8
2020-02-13 23:17:22.190 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 3.80000000 to 3.90000000
2020-02-13 23:41:59.739 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 3.90000000 to 4.00000000
2020-02-13 23:54:06.375 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.00000000 to 4.10000000
2020-02-14 00:10:08.052 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.10000000 to 4.20000000
2020-02-14 00:22:10.325 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.20000000 to 4.30000000
2020-02-14 01:11:23.548 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.30000000 to 4.40000000
2020-02-14 01:31:28.793 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.40000000 to 4.50000000
2020-02-14 01:43:31.774 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.50000000 to 4.60000000
2020-02-14 02:12:39.363 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.60000000 to 4.70000000
2020-02-14 03:12:54.142 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.70000000 to 4.80000000
2020-02-14 03:54:06.535 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.80000000 to 4.70000000
2020-02-14 04:02:08.511 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.70000000 to 4.60000000
2020-02-14 04:10:11.521 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.60000000 to 4.50000000
2020-02-14 04:18:14.898 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.50000000 to 4.40000000
2020-02-14 04:26:17.071 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.40000000 to 4.30000000
2020-02-14 04:30:38.061 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.30000000 to 4.20000000
2020-02-14 04:38:20.101 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.20000000 to 4.10000000
2020-02-14 04:47:22.481 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.10000000 to 4.00000000
2020-02-14 04:59:25.475 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.00000000 to 3.90000000
2020-02-14 05:15:29.791 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 3.90000000 to 3.80000000
2020-02-14 05:51:38.810 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 3.80000000 to 3.90000000
2020-02-14 06:08:42.946 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 3.90000000 to 4.00000000
2020-02-14 06:20:47.181 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.00000000 to 4.10000000
2020-02-14 06:32:50.227 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.10000000 to 4.20000000
2020-02-14 06:44:53.206 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.20000000 to 4.30000000
2020-02-14 07:03:00.021 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.30000000 to 4.40000000
2020-02-14 07:13:00.019 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.40000000 to 4.50000000
2020-02-14 08:03:00.044 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.50000000 to 4.40000000
2020-02-14 08:33:00.024 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.40000000 to 4.30000000
2020-02-14 09:13:00.038 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.30000000 to 4.40000000
2020-02-14 09:23:00.055 [vent.ItemStateChangedEvent] - UG_TECHNIK_FW_Aussentemperatur_C changed from 4.40000000 to 4.50000000
I will put this rules to time triggered rules and than switch step by step to the next-rule gen engine.
Are you running on an SD card? If so, when was the last time you replaced it?
Note that a rule that “stops” is not necessarily any kind of problem. Some other rule may have gobbled up all the available threads, meaning others cannot start.
Looks like a big clue. “That can’'t happen” of course, because the variable is defined as the rules file is initialised. Except it is happening - so it tells us your rule file(s) is reloading.
What’s going on in your openhab.log, is that a filtered view we are looking at?
I suspect one of two things that seem to afflict some 2.5 users - one has to do with a messed up addons.config, the other is to do with Things changing and causing “system started” events.
No, I running on an HDD over the USB3-Port. I think that should be fine.
Yes, but I don’t now why the error occurs. In the openhab.log I don’t see any reloading files outside I restart openhab or change the rules manually.
I started the next-gen rule engine
 and it seems to work :slight_smile:
2020-02-14 22:07:36.263 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'py' with identifier: file:/etc/openhab2/automation/jsr223/python/personal/hello_world.py
2020-02-14 22:07:39.520 [DEBUG] [jsr223.jython.core.triggers         ] - when: target=[Time cron 0/10 * * * * ?], target_type=Time, trigger_target=cron, trigger_type=0/10 * * * * ?, old_state=None, new_state=None
2020-02-14 22:07:40.237 [DEBUG] [jsr223.jython.core.triggers         ] - when: Created cron_trigger: [Time_cron_0_10_0884a8cf4f6e11eaa917dca6320af300]
2020-02-14 22:07:40.244 [DEBUG] [jsr223.jython.core.rules            ] - Added rule [Jython Hello World (cron decorators)]
2020-02-14 22:07:40.317 [DEBUG] [le.handler.GenericCronTriggerHandler] - Scheduled cron job '0/10 * * * * ?' for trigger 'Time_cron_0_10_0884a8cf4f6e11eaa917dca6320af300_08e20b0f4f6e11ea94a9dca6320af300'.
2020-02-14 22:07:50.316 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger 'Time_cron_0_10_0884a8cf4f6e11eaa917dca6320af300_08e20b0f4f6e11ea94a9dca6320af300' of rule 'c8f3842a-22e4-4f4b-9337-8a608b86073d' is triggered.
2020-02-14 22:07:50.335 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2020-02-14 22:07:50.338 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule 'c8f3842a-22e4-4f4b-9337-8a608b86073d' is executed.
Well, it’s up to you. I wouldn’t be initiating major changes to an obviously sick system without some idea of what’s wrong. Good luck.
When i update the hello_world.py file, I can’t see that the is reloaded.
Can I reload it manually or do I have to restart openhab completely?
:tada:
I’m not sure what you mean. When you touch or save a script, it will reload just as with the old rule engine.
Sorry, my mistake :see_no_evil: I changed a hello_world.py-file, but one which was not in the folder openhab2-conf\automation\jsr223\python\personal\
It seems to work great, so I will move step by step now. Thanks!
Yesterday I had the time to go on a step. I also update the openhab.
Now the version openHAB 2.5.3-1 (Release Build) is running
but when I start openhab I got following error message
2020-04-12 10:33:28.250 [WARN ] [org.apache.felix.fileinstall        ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.core.automation.module.script.scriptenginefactory.jython-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.core.automation.module.script.scriptenginefactory.jython [203]
  Unresolved requirement: Import-Package: org.openhab.core.automation.module.script; version="[2.5.0,3.0.0)"
I tried following but without success:
Is there a new org.openhab.core.automation.module.script.scriptenginefactory.jython-2.5.0-SNAPSHOT.jar or ``org.openhab.core.model.script-2.5.0-SNAPSHOT.jar` to download?
Thanks a lot
Why are you trying to install that jar? Do you need the headers for the http actions? That’s the only reason to install it.
Anyway, what do you see when you list the bundles on the console?
bundle:list -s | grep script
I have:
173 x Active x  80 x 2.5.0                   x org.openhab.core.model.script.ide
174 x Active x  80 x 2.5.0                   x org.openhab.core.model.script.runtime
203 x Active x  80 x 2.5.0.202001221001      x org.openhab.core.automation.module.script.scriptenginefactory.jython
260 x Active x  80 x 2.5.0                   x org.openhab.core.automation.module.script
261 x Active x  80 x 2.5.0                   x org.openhab.core.automation.module.script.rulesupport
276 x Active x  75 x 2.5.3                   x org.openhab.transform.javascript
289 x Active x  80 x 2.5.0.201912191214      x org.openhab.core.model.script
If you have the beta Jython bundle in addons, this is normal after the cache has been cleared
 just wait a minute and the dependencies should be resolved and everything will work. If not, restart OH again.
The org.openhab.core.model.script-2.5.0-SNAPSHOT.jar is no longer needed after 2.5.0 stable and has been removed from the Google Drive link. There have been a few updates to the org.openhab.core.automation.module.script.scriptenginefactory.jython-2.5.0-SNAPSHOT.jar, but nothing really important unless you use third party modules.
