Dear community,
with the availibility of Oh2.5.6 I migrated from a RPi2 to a Docker based setup running on a Synology NAS (DS 720+, 4 Cores, 18 GB RAM).
Although I had some struggels with the container setup, everything worked fine for a time.
After upgrading to OH 2.5.7 rules stopped triggering after 1-3 days.
The logs showed nothing unusual.
Re-Creation of the container usually solved the issue, but this is not really satisfying.
After Upgrading to OH 2.5.9 rules stopped triggering after 4-16 hours.
Again nothing appeared in the logs.
Downgrading to OH 2.5.7 changed back to runtimes about 1-3 days before the rules stopped working.
It does not matter, if rules should trigger at a change of luminance, manually triggered switches or cron-based rules. Everything just stops working.
Looking in the logs, events are still beeing received, just not processed.
I also searched the docs and found plenty of issues which sound similar, but are not matching my situation.
Example:
a rule to determine if it is dark or light outside.
Based on this information, garden lights are changed to ON or blinds are moved up or down.
rule "toggleBrightnessLevelOutdoor"
when Item brightnessOutdoorSouth changed
if (brightnessOutdoorSouth.state < 135 && brightnessLevelOutdoor.state == 1
|| brightnessOutdoorSouth.state < 135 && brightnessLevelOutdoor.state.equals(NULL)) {
sendCommand(brightnessLevelOutdoor, 0) //dark
// logInfo("rule", "- Outoor Brightness "+ brightnessOutdoorSouth.state+ ", Switcht
brightnessLevel to 0 / dunkel ")
} else if (brightnessOutdoorSouth.state >= 145 && brightnessLevelOutdoor.state == 0
|| brightnessOutdoorSouth.state >= 145 && brightnessLevelOutdoor.state.equals(NULL)
// logInfo("rule", "- Outdoor Brightness "+ brightnessOutdoorSouth.state+ ", Switcht
brightnessLevel to 1 / hell ")
sendCommand(brightnessLevelOutdoor, 1) //light
The log still shows the ItemChanged event, but the rule does not trigger
[vent.ItemStateChangedEvent] - brightnessOutdoorSouth changed from 194 to 195
The rule above is just one of many rules which stopped triggering and have workd for years earlier.
Any idea or hint to figure out the root cause of this?
I try to figure out the roout cause of this, but after weeks without success, and days between the occurences, I start to go nuts…
