Issue of the topic: userdata/logs/openhab.log contains validation errors for rules, sitemap, … like
2019-04-09 11:38:57.872 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'default.things', using it anyway:
Provide a thing type ID and a thing ID in this format:
<thingTypeId> <thingId>
Is there a way to run the validation that causes such logs manually,
so that I do not nave to restart openHAB and investigate log files after every change?
Some things seem not to work reliably without restarting after modifications, at least sometimes. (for example IRTrans Ethernet Bridge, Generic MQTT Thing)
Anyway, the question still stands if there is a way to invoke this manually and get direct feedback instead of searching through log files.
You get “instant feedback” when saving the file, but that is in the logs. What is wrong with that?
Using the “openhab logviewer” you have direct access to the logs!
