I have created a rule that sends out a email when the temperature is higher the 80C
rule "Temperature above 80°"
Item temperature received update
if (temperature.state >= 18) {
sendMail("myemail@adress", "Kachel Temperatuur Waarschuwing", "Kachel temperatuur is 80C of hoger$
Now my question: is it possible to change the rule so that when the temperature is higher then 80C it will send a email unless the email has already been send in the past 10 minutes?
Use another item and the expire binding Install the expire binding
Item:
Switch MailSent { expire="10m, command=OFF" }
Rules:
if (temperature.state >= 18 && MailSent.state != ON) {
sendMail("email@email.com", "Kachel Temperatuur Waarschuwing", "Kachel temperatuur is 80C of hoger")
MailSent.sendCommand(ON)
The rule will sent a command ON to MailSent. MailSent is like a timer and will turn itself to OFF after 10 minutes.
