Ok it´s not working.
I did a small test and changed the createTimer to plusSeconds(60).
The rule started when changing the state from closed to open.
2016-07-08 18:05:27.209 [DEBUG] [m.r.internal.engine.RuleEngine] - Executing rule 'Warnung f?r Fensterkontakt'
But crashed after 60 seconds.
2016-07-08 18:06:27.478 [DEBUG] [.s.i.actions.TimerExecutionJob] - Executing timer 'DEFAULT.2016-07-08T18:06:27.466+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@e80fb6 (explicitSyntax: true)'
2016-07-08 18:06:27.605 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2016-07-08T18:06:27.466+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@e80fb6 (explicitSyntax: true) threw an unhandled Exception:
java.lang.IllegalStateException: Ambiguous methods [protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(org.eclipse.xtext.xbase.XAssignment,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(org.eclipse.xtext.xbase.XBlockExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBooleanLiteral(org.eclipse.xtext.xbase.XBooleanLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateCastedExpression(org.eclipse.xtext.xbase.XCastedExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateClosure(org.eclipse.xtext.xbase.XClosure,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateConstructorCall(org.eclipse.xtext.xbase.XConstructorCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected org.eclipse.xtext.xbase.interpreter.IEvaluationResult org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateDoWhileExpression(org.eclipse.xtext.xbase.XDoWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateForLoopExpression(org.eclipse.xtext.xbase.XForLoopExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(org.eclipse.xtext.xbase.XIfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateInstanceOf(org.eclipse.xtext.xbase.XInstanceOfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(org.eclipse.xtext.xbase.XMemberFeatureCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNullLiteral(org.eclipse.xtext.xbase.XNullLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNumberLiteral(org.eclipse.xtext.xbase.XNumberLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateReturnExpression(org.eclipse.xtext.xbase.XReturnExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateStringLiteral(org.eclipse.xtext.xbase.XStringLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateSwitchExpression(org.eclipse.xtext.xbase.XSwitchExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateThrowExpression(org.eclipse.xtext.xbase.XThrowExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTryCatchFinallyExpression(org.eclipse.xtext.xbase.XTryCatchFinallyExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTypeLiteral(org.eclipse.xtext.xbase.XTypeLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateVariableDeclaration(org.eclipse.xtext.xbase.XVariableDeclaration,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateWhileExpression(org.eclipse.xtext.xbase.XWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator)] for params [null, org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext@1d990ab, org.eclipse.xtext.util.CancelIndicator$1@1d11635]
at org.eclipse.xtext.util.PolymorphicDispatcher.handleAmbigousMethods(PolymorphicDispatcher.java:308) ~[na:na]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:283) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:329) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_65]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:28) ~[na:na]
at com.sun.proxy.$Proxy82.apply(Unknown Source) ~[na:na]
at org.openhab.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:44) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) ~[quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
2016-07-08 18:06:27.621 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2016-07-08T18:06:27.466+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@e80fb6 (explicitSyntax: true) threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:224) ~[quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalStateException: Ambiguous methods [protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(org.eclipse.xtext.xbase.XAssignment,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(org.eclipse.xtext.xbase.XBlockExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBooleanLiteral(org.eclipse.xtext.xbase.XBooleanLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateCastedExpression(org.eclipse.xtext.xbase.XCastedExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateClosure(org.eclipse.xtext.xbase.XClosure,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateConstructorCall(org.eclipse.xtext.xbase.XConstructorCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected org.eclipse.xtext.xbase.interpreter.IEvaluationResult org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateDoWhileExpression(org.eclipse.xtext.xbase.XDoWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateForLoopExpression(org.eclipse.xtext.xbase.XForLoopExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(org.eclipse.xtext.xbase.XIfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateInstanceOf(org.eclipse.xtext.xbase.XInstanceOfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(org.eclipse.xtext.xbase.XMemberFeatureCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNullLiteral(org.eclipse.xtext.xbase.XNullLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNumberLiteral(org.eclipse.xtext.xbase.XNumberLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateReturnExpression(org.eclipse.xtext.xbase.XReturnExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateStringLiteral(org.eclipse.xtext.xbase.XStringLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateSwitchExpression(org.eclipse.xtext.xbase.XSwitchExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateThrowExpression(org.eclipse.xtext.xbase.XThrowExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTryCatchFinallyExpression(org.eclipse.xtext.xbase.XTryCatchFinallyExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTypeLiteral(org.eclipse.xtext.xbase.XTypeLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateVariableDeclaration(org.eclipse.xtext.xbase.XVariableDeclaration,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateWhileExpression(org.eclipse.xtext.xbase.XWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator)] for params [null, org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext@1d990ab, org.eclipse.xtext.util.CancelIndicator$1@1d11635]
... 1 common frames omitted
Any ideas ?
Cheers
Michael
