[SOLVED] Sensative 11-01-011 Strips-MaZw no events from device
2.5.0-SNAPSHOT Build #1558
Included a Sensative Strip today. Inclusion seemed to go fine, but no events from the device is seen in the z-wave debug log.
Have tried a full system power off/on.
Param 1 set to Binary Sensor Report.
Log below from restart.
Note last line: NODE 116: Unknown association group 1
2019-03-23 22:58:11.700 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Channel zwave:device:f180343d:node116:battery-level linked - polling started.
2019-03-23 22:58:11.700 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Channel zwave:device:f180343d:node116:alarm_tamper linked - polling started.
2019-03-23 22:58:11.702 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Channel zwave:device:f180343d:node116:sensor_door linked - polling started.
2019-03-23 22:58:15.048 [DEBUG] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 116: Node found
2019-03-23 22:58:15.130 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - NODE 116: Init node thread start
2019-03-23 22:58:15.920 [DEBUG] [ternal.protocol.initialization.ZWaveNodeSerializer] - NODE 116: Serializing from file /var/lib/openhab2/zwave/network_e0b2d700__node_116.xml
2019-03-23 22:58:15.921 [DEBUG] [ternal.protocol.initialization.ZWaveNodeSerializer] - NODE 116: Error serializing from file: file does not exist.
2019-03-23 22:58:16.402 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 116: Starting initialisation from EMPTYNODE
2019-03-23 22:58:16.448 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 116: Node advancer - advancing to IDENTIFY_NODE
2019-03-23 22:58:16.626 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 116: Node advancer: Initialisation starting
2019-03-23 22:58:16.447 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - NODE 116: Init node thread finished
2019-03-23 22:58:16.675 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: ProtocolInfo
2019-03-23 22:58:16.675 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Listening = false
2019-03-23 22:58:16.675 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Routing   = true
2019-03-23 22:58:16.675 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Beaming   = true
2019-03-23 22:58:16.675 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Version   = 4
2019-03-23 22:58:16.675 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: FLIRS     = false
2019-03-23 22:58:16.676 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Security  = false
2019-03-23 22:58:16.676 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Max Baud  = 40000
2019-03-23 22:58:16.676 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Basic    = BASIC_TYPE_ROUTING_SLAVE
2019-03-23 22:58:16.676 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Generic  = GENERIC_TYPE_SENSOR_NOTIFICATION
2019-03-23 22:58:16.676 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 116: Specific = SPECIFIC_TYPE_NOTIFICATION_SENSOR
2019-03-23 22:58:16.676 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 116: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2019-03-23 22:58:16.677 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 116: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2019-03-23 22:58:16.677 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 116: Version = 1, version set. Enabling extra functionality.
2019-03-23 22:58:16.677 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 116: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2019-03-23 22:58:16.678 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 116: Creating new instance of command class COMMAND_CLASS_BASIC
2019-03-23 22:58:16.680 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 116: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2019-03-23 22:58:16.680 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 116: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2019-03-23 22:58:16.900 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 116: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@5ddf3644
2019-03-23 22:58:16.900 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 116: Node Init transaction completed with response COMPLETE
2019-03-23 22:58:16.900 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 116: Node advancer - advancing to REQUEST_NIF
2019-03-23 22:58:16.901 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 116: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@82bacdc
2019-03-23 22:58:16.909 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 116: Bump transaction 11 priority from Controller to Immediate
2019-03-23 22:58:16.946 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 116: Adding to device queue
2019-03-23 22:58:16.946 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 116: Added 11 to queue - size 1
2019-03-23 22:58:18.474 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Controller status changed to ONLINE.
2019-03-23 22:58:18.474 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Controller is ONLINE. Starting device initialisation.
2019-03-23 22:58:18.474 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Updating node properties.
2019-03-23 22:58:18.474 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Updating node properties. MAN=2147483647
2019-03-23 22:58:18.474 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Properties synchronised
2019-03-23 22:58:18.503 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Initialising Thing Node...
2019-03-23 22:58:18.550 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Initialising cmd channel zwave:device:f180343d:node116:sensor_door for OpenClosedType
2019-03-23 22:58:18.551 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Initialising state channel zwave:device:f180343d:node116:sensor_door for OpenClosedType
2019-03-23 22:58:18.570 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Initialising cmd channel zwave:device:f180343d:node116:alarm_tamper for OnOffType
2019-03-23 22:58:18.570 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Initialising state channel zwave:device:f180343d:node116:alarm_tamper for OnOffType
2019-03-23 22:58:18.570 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Initialising cmd channel zwave:device:f180343d:node116:battery-level for PercentType
2019-03-23 22:58:18.570 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Initialising state channel zwave:device:f180343d:node116:battery-level for PercentType
2019-03-23 22:58:18.575 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Polling intialised at 86400 seconds - start in 11145600 milliseconds.
2019-03-23 22:58:18.575 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Device initialisation complete.
Set Association group 1 to controller here.
2019-03-23 23:07:29.842 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Channel zwave:device:f180343d:node116:sensor_door unlinked - polling stopped.
2019-03-23 23:07:29.843 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Channel zwave:device:f180343d:node116:sensor_door linked - polling started.
2019-03-23 23:08:17.691 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Configuration update received
2019-03-23 23:08:17.701 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Configuration update set group_1 to controller (String)
2019-03-23 23:08:17.702 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Association [controller] consolidated to {}
2019-03-23 23:08:17.702 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 116: Unknown association group 1
Here firmware is 0.0, but I’m pretty sure is was 0.8 just after inclusion and before power cycling.
Anyone?
Found the solution here:
Had to reset strip and re-include.
Works fine now.
