Hi there
i have a problem with the SenseoWifi Openhab Project from ThomDietrich
I removed the .example from config.json and added my data
then i pressed upload and everything went well. but i still can not see the Senseo in my Wifi networt.
Uploading the sketch does not upload the config in parallel.
You would need to upload the SPIFFS Image too.
If you use Platform io there should be a task for that.
The config file from the screenshot looks valid from what i can see.
Unfortunately i can’t tell you more.
I am using it on VSCode and there is a task Button beside the build/upload buttons.
I could imagine that this is similar in atom. Look for something with spiffs in the name.
