here it is, consider that I’m still working on it so it’s not tidy and clean.
I think the error is in “void callback” at the setpoint entry. I put a question mark in the payload value
#include <ESP8266WiFi.h>
#include <EEPROM.h>
#include <WiFiClientSecure.h>
#include <ESP8266TelegramBOT.h>
#include <ESP8266WebServer.h>
#include <PubSubClient.h>
#include <Bounce2.h>
#include <ESP8266mDNS.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <IRsend.h>
#include <DHT.h>
//NEXTION
#include <SoftwareSerial.h>
#include <Nextion.h>
SoftwareSerial nextion(4, 2);// Nextion TX to pin 2 and RX to pin 3 of Arduino
Nextion myNextion(nextion, 9600); //create a Nextion object named myNextion using the nextion serial port @ 9600bps
#define DHTPIN 0
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE, 20);
IPAddress staticIP(xxxxx);
IPAddress gateway(xxxxxxx);
IPAddress subnet(xxxxx);
IPAddress dns1(8, 8, 8, 8);
IPAddress dns2(8, 8, 4, 4);
const char* ssid = "xxxxxxx";
const char* password = "xxxxxxxx";
const char* mqtt_server = "xxxxxxxx";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
unsigned long previousMillis = 0; // intervallo lettura temperature
unsigned long previousMillis2 = 0; // intervallo timer
unsigned long previousMillis3 = 0; // intervallo MQTT
const long interval = 10000; //intervallo 10 secondi lettura temperature
const long interval2 = 1000; //imposta intervallo timer ++ a un secondo
const long interval3 = 11000; //intervallo 1 minuto MQTT
String topicString = "";
const int relayPin = 14; //D5
int stato_rele = 0;
float setpoint = 0;
float bloccaLetturaSet = 0;
float bloccaLetturaTemp = 0;
float bloccaLetturaUmy = 0;
float SETpointAvvio = 16.00;
float SETpointECO = 20.00;
float SETpointNORMAL = 22.00;
float SETpointCOMFORT = 25.00;
float SETpointTIMER = 30.00;
float MaxTemp = 35.00;
float MinTemp = 15.00;
int vecchio_stato = 0;
int bloccadimmer = 0;
int dimmer = 0;
int sistema = 0;
int flag_sistema = 0;
int flag_timer = 0;
int val;
int timerPlus, timerMinus;
WiFiUDP ntpUDP;
int16_t utc = 2; //UTC (1 ora solare) (2 ora legale)
NTPClient timeClient(ntpUDP, "europe.pool.ntp.org", utc * 3600, 60000);
const char* inTopic_sistema = "openhab/dst2/sistema/command";
const char* inTopic_setpoint = "openhab/dst2/setpoint/command";
const char* switchTopic_sistema = "openhab/dst2/sistema/state";
const char* switchTopic_temperature = "openhab/dst2/temperature/state";
const char* switchTopic_humidity = "openhab/dst2/humidity/state";
const char* switchTopic_setpoint = "openhab/dst2/setpoint/state";
//********************************************** funzioni ***************************************************************
void setup_wifi() {
delay(10);
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.config(staticIP, gateway, subnet, dns1, dns2);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
for (int i = 0; i < 500; i++) {
delay(1);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
Serial.println();
Serial.print("MAC: ");
Serial.println(WiFi.macAddress());
void refreshTheme() {
float humidity = dht.readHumidity();
float temperatura = dht.readTemperature();
if (sistema == 0) {
// myNextion.sendCommand("page page2");//page attendere
// delay(500);
digitalWrite(relayPin, LOW);
myNextion.sendCommand("page page0");//home
myNextion.setComponentText("t0", String(setpoint));
myNextion.setComponentText("t3", String(timerPlus ) + String("m"));
timeClient.update();
myNextion.setComponentText("t4", String(timeClient.getFormattedTime()));
myNextion.sendCommand("b0.picc=0");//power off
myNextion.setComponentText("t8", "");//fiamma off
if ( sistema == 1) {
// delay(500);
myNextion.setComponentText("t3", String(timerPlus) + String("m"));
myNextion.sendCommand("b0.picc=1");//power on
//myNextion.setComponentText("t9", "");
if ( sistema == 2) {
// delay(500);
myNextion.setComponentText("t9", "");//fiamma on
myNextion.setComponentText("t1", String(temperatura));
myNextion.setComponentText("t2", String(humidity));
void lettura_temperatura() {
unsigned long currentMillis = millis();
if (currentMillis - previousMillis > interval) {
if (temperatura == bloccaLetturaTemp) { //NON FARE NULLA
} else {
if ( temperatura != bloccaLetturaTemp) {
client.publish(switchTopic_temperature, String(temperatura).c_str(), true);
bloccaLetturaTemp = temperatura;
if (temperatura > MinTemp) {
myNextion.setComponentText("t10", "");
} else {
myNextion.setComponentText("t11", "");
if (humidity == bloccaLetturaUmy) { //SE CAMBIA UMY AGGIORNA IL NEXTION
} else {
if ( humidity != bloccaLetturaUmy) {
client.publish(switchTopic_humidity, String(humidity).c_str(), true);
bloccaLetturaUmy = humidity;
myNextion.setComponentText("t3", String(timerPlus / 60) + String("m"));
previousMillis = currentMillis;
void callback(char* topic, byte* payload, unsigned int length) {
topicString = topic;
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
// sistema
float temperatura_casa = dht.readTemperature();
if (topicString == "openhab/dst2/sistema/command") {
if ((char)payload[1] == 'N') { //sistema on
if (flag_sistema == 0) {
sistema = 1;
flag_sistema = 1;
if ((setpoint > temperatura_casa) && (sistema == 1)) {
digitalWrite(relayPin, HIGH);
sistema = 2;
refreshTheme();
if ((setpoint < temperatura_casa) && (sistema == 2)) {
sistema = 1;
refreshTheme();
if ((char)payload[1] == 'F') { //sistema off
if ((flag_sistema == 1) || (flag_sistema == 2)) {
sistema = 0;
flag_sistema = 0;
flag_timer = 0;
timerPlus = 0;
refreshTheme();
// setpoint
if (topicString == "openhab/dst2/setpoint/command") {
if ((char)payload[0] == '?') {
//????? code here
myNextion.setComponentText ("t0", String (setpoint));
//????? code here
void reconnect() {
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
if (client.connect("termostato")) {
Serial.println("connected");
//Subscribe to incoming commands
client.subscribe(inTopic_sistema);
client.subscribe(inTopic_setpoint);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
for (int i = 0; i < 5000; i++) {
delay(1);
//********************************************** SETUP ***************************************************************
void setup() {
myNextion.init();
Serial.begin(9600);
setup_wifi();
timeClient.begin();
client.setServer(mqtt_server, xxxxx); //connect to MQTT
client.setCallback(callback);
String line = "";
dht.begin();
while (isnan(humidity) || isnan(temperatura)) { // t o h a volte è nan, non inviare il valore nan agli slot
Serial.println(temperatura);
Serial.println(humidity);
myNextion.setComponentText("t6", "");
myNextion.setComponentText("t3", String("----"));
Serial.println(timeClient.getFormattedTime());
myNextion.sendCommand("dims=100");
if (WiFi.status() != WL_CONNECTED) {
} else {
myNextion.setComponentText("t7", "");
pinMode(relayPin, OUTPUT);
setpoint++;
//********************************************** LOOP ***************************************************************
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
lettura_temperatura();
stato_rele = (digitalRead, relayPin);
//////////////////////////////inizio nextion listen ///////////////////////////////
String message = myNextion.listen(); {
if (message != "") {
Serial.println(message);
if (message == "65 1 7 1 ff ff ff") {
refreshTheme();
/////////////////////////// on-off sistema///////////////////////////////
if (message == "65 10 1 ff ff ff") {
sistema = 1;
flag_sistema = 1;
refreshTheme();
client.publish(switchTopic_sistema, "ON", true);
else if ((flag_sistema == 1) || (flag_sistema == 2)) {
sistema = 0;
flag_sistema = 0;
flag_timer = 0;
timerPlus = 0;
refreshTheme();
client.publish(switchTopic_sistema, "OFF", true);
/////////////////////////////////// setpoint //////////////////////////////////
if (message == "65 2 1 ff ff ff") {
setpoint++;
client.publish(switchTopic_setpoint, String(setpoint).c_str(), true);
if (message == "65 3 1 ff ff ff") {
setpoint--;
//////////////////////// sistema on-off con il setpoint /////////////////////////
sistema = 2;
refreshTheme();
sistema = 1;
refreshTheme();
//////////////////////// timer /////////////////////////////////////////////
if (message == "65 1 1 1 ff ff ff") { //timer 1 ora
setpoint = SETpointTIMER;
sistema = 2;
flag_sistema = 1;
flag_timer = 1;
refreshTheme();
if (message == "65 1 2 1 ff ff ff") { //timer 2 ore
sistema = 2;
flag_sistema = 1;
flag_timer = 1;
refreshTheme();
if (message == "65 1 3 1 ff ff ff") { //timer 3 ore
sistema = 2;
flag_sistema = 1;
flag_timer = 1;
refreshTheme();
//////////////////////// preimpostate //////////////////////////////////////
if (message == "65 1 4 1 ff ff ff") { //economy 20 gradi
setpoint = SETpointECO;
sistema = 2;
flag_sistema = 1;
refreshTheme();
if (setpoint > temperatura_casa) {
if (message == "65 1 5 1 ff ff ff") { //normal 22 gradi
setpoint = SETpointNORMAL;
sistema = 2;
flag_sistema = 1;
refreshTheme();
if (message == "65 1 6 1 ff ff ff") { //confort 25 gradi
setpoint = SETpointCOMFORT;
sistema = 2;
flag_sistema = 1;
refreshTheme();
if (flag_timer == 1) {
if (currentMillis - previousMillis2 >= interval2) {
previousMillis2 = currentMillis;
timerPlus++;
if (timerPlus >= 3600) {
sistema = 0;
flag_timer = 0;
timerPlus = 0;
refreshTheme();
timerPlus++;
if (timerPlus >= 7200) {
sistema = 0;
flag_timer = 0;
timerPlus = 0;
refreshTheme();
timerPlus++;
if (timerPlus >= 10800) {
sistema = 0;
flag_timer = 0;
timerPlus = 0;
refreshTheme();
//Serial.println("timerPlus" + String(timerPlus));
//Serial.println("flag_timer" + String(flag_timer));
//Serial.println("interval2" +String(previousMillis2));
//Serial.println(temperatura);
//Serial.println("flag_sistema" + String(flag_sistema));
// Serial.println("sistema" + String(sistema));
// Serial.println("stato rele" + String(stato_rele));
// Serial.print((char)payload[i]);
