I had several setpoints working just dandy but went through a clean build upgrade to 2.4.0-1 (Release Build). I loaded back in all my items etc. and have almost every all tidy again and running much better. However, I am having issues with my setpoints. The sitemap page displays just fine but I cannot set any number. ie, you touch the screen (android) and you get nothing. no errors in the log either. so here is what i have, i’ll just use one example…
Items
Switch Shutter1 "Shutter 1" <switch> (persist,gAllShutters) [ "Switchable"]
{ mqtt=">[broker:cmnd/sonoff-A86541/POWER:command:*:default],
<[broker:stat/sonoff-A86541/POWER:state:default]" }
Number Shutter1_Thermostat_SP_F "Set Point [%.1f]" { mqtt=">[broker:cmnd/sonoff-A86541/POWER:command:*:default]" }
Sitemap
sitemap settings label="Settings"
Frame label="Settings"
Setpoint item=Shutter1_Thermostat_SP_F label="Shutter One Temp [%.0f °F]" icon="heating" step=1
Setpoint item=Shutter2_Thermostat_SP_F label="Shutter Two Temp [%.0f °F]" icon="heating" step=1
Setpoint item=SingleSpeedFan_Thermostat_SP_F label="Single Fan Temp [%.0f °F]" icon="heating" step=1
Setpoint item=LowFan_Thermostat_SP_F label="Low Fan Temp [%.0f °F]" icon="heating" step=1
Setpoint item=PropaneRemaining minValue=0 maxValue=300 step=5
Setpoint item=Thermostat_SP_F label="Heat Desired Temp [%.0f °F]" icon="heating" step=1
// Setpoint item=Table_Heater_Thermostat_SP_F label="Grow Table Temp [%.0f °F]" icon="heating" step=1
Setpoint item=Gravity_Tank_PH label="Gravity Tank PH [%.2f] "minValue=3.0 maxValue=6 step=0.01
//Setpoint item=Solar_Soll1 minValue=1 maxValue=10 step=1
Thoughts on this would be very helpful!
Thanks!
