Heya
I am using hometop to controll my heating unit. To set the desired temperature I’d like to switch to MQTT.
I managed to read the current state, yet I fail to set the desired temperature with a setpoint in my sitemap.
The item configuration looks like this:
Number Temperature_Setpoint "Zieltemperatur [%.1f °C]" <temperature> {mqtt="<[mosquitto:hometop/ht/hc1_Tdesired:state:default:.*],>mosquitto:set/hometop/ht/hc1_Tdesired:command:*:${command}]]"}
The problem is, that setpoint seem to publish only the number of the desired temperature. However the mqtt broker expects the temperature and a second parameter. e.g “heizen”
mosquitto_pub -d -t set/hometop/ht/hc1_Tdesired -m "29.5,heizen"
I dunno if one can tweak the SetPoint control to add the second parameter “heizen” or if I have to use a rule to do so.
