I am using the shelly 1 native mqtt service, when i send on or off from openhab it works and the icon on my panel changes with it, but if i turn the shelly on or off via the attached light switch it does not get update on openhab, i can see the mqtt messages sent to the mqtt server when pressing the light switch.
shellies/shelly1-3288D6/relay/0 on
shellies/shelly1-3288D6/relay/0 off
this is my item.
//Shelly Units
Switch Shelly_1 “Shelly 1” [“Switchable”] {mqtt=">[broker:shellies/shelly1-3288D6/relay/0/command:command:on:on],>[broker:shellies/shelly1-3288D6/relay/0/command:command:off:off],<[broker:shellies/shelly1-3288D6/relay/0:state:default]"}
not sure what i have wrong on the inbound <[broker:shellies/shelly1-3288D6/relay/0:state:default]
rrichard
(Richard)
December 7, 2018, 8:30pm
#2
Hello Gary,
for a Shelly 1 device with 6.3.0 Tasmota Firmware running, this is my working item in OpenHAB:
Switch Light "small Light" { mqtt=">[mqttbroker:test/switch/cmnd/Flur_Treppenlicht/POWER:command:*:default], <[mqttbroker:test/switch/stat/Flur_Treppenlicht/POWER:state:default]" }
the Shelly has these MQTT settings:
Are you using the HomeKit Binding?
Hi Richard
I am NOT using Tasmota I’m using the new Shelly firmware that has mqtt included.
Thanks for the reply.
vzorglub
(Vincent Regaud)
December 7, 2018, 10:25pm
#4
According to the Sheely website your topic is correct.
You need a MAP transform to change on
to ON
and off
to OFF
Create a shelliesonoff.map file in the transform folder with the following content:
on=ON
off=OFF
ON=off
OFF=on
Your item:
Switch Shelly_1 "Shelly 1" [ "Switchable" ] { mqtt=">[broker:shellies/shelly1-3288D6/relay/0/command:command:*:MAP(shelliesonoff.map)],<[broker:shellies/shelly1-3288D6/relay/0:state:MAP(shelliesonoff.map)]" }
when I set it that way nothing works, I see mqtt traffic but device does not react.
shellies/shelly1-3288D6/relay/0/command MAP(shelliesonoff.map)
vzorglub
(Vincent Regaud)
December 7, 2018, 11:25pm
#6
You may need to install the MAP transformation in the paperUI
Thank you both, I had not used MAP before so yes it was needed to be installed in paper UI, also I changed the map file and it worked, I love these little units fits in the electrical box and no need to flash tasmota.
on=ON
off=OFF
ON=on
OFF=off
Brignoud
(Elenio)
January 11, 2019, 2:38pm
#8
Please, which is the THING I have to specify with the Shelly?
I will configure it as a Switch
H102
(CM6.5 H102)
January 11, 2019, 2:49pm
#9
Are you using mqtt binding version 2.4 or 1.x?
Brignoud
(Elenio)
January 11, 2019, 9:53pm
#10
just installed 2.4
(thank you)
rkrisi
(Kristof Rado)
January 11, 2019, 9:55pm
#11
If you are using MQTT Binding 2.4, you don’t even need to have a MAP transform. You can define specific ON/OFF values for the Switch item type in the channel configuration.
Brignoud
(Elenio)
January 11, 2019, 10:14pm
#12
can I ask to show me an example
IJust defined the broker thing in file as follow
mqtt:broker:myBroker [ host="192.168.xx.xx", secure=false ]
but I’m stucked as I don’t understand how to create the needed channels type in config files
rkrisi
(Kristof Rado)
January 11, 2019, 10:31pm
#13
I have configured my through PaperUI, but it should work from files as well. Please use the provided example from the docs:
Bridge mqtt:broker:myUnsecureBroker [ host="192.168.0.42", secure=false ]
Thing topic mything {
Channels:
Type switch : lamp "Kitchen Lamp" [ stateTopic="lamp/enabled", commandTopic="lamp/enabled/set" ]
Type switch : fancylamp "Fancy Lamp" [ stateTopic="fancy/lamp/state", commandTopic="fancy/lamp/command", on="i-am-on", off="i-am-off" ]
Type string : alarmpanel "Alarm system" [ stateTopic="alarm/panel/state", commandTopic="alarm/panel/set", allowedStates="ARMED_HOME,ARMED_AWAY,UNARMED" ]
Type color : lampcolor "Kitchen Lamp color" [ stateTopic="lamp/color", commandTopic="lamp/color/set", rgb=true ]
Type dimmer : blind "Blind" [ stateTopic="blind/state", commandTopic="blind/set", min=0, max=5, step=1 ]
So the Bridge connects to your MQTT Broker, and you add Things to this bridge, which should be your MQTT devices. Channels should be the used topics in that device.
As you can see, this is how you can add specific on off values to a switch item.
You will need on=“on”, off=“off” for Shelly devices
mikael
(Mikaël)
January 13, 2019, 10:42pm
#14
Can you post a screenshot of how you configure the transformation in the channel through paperUI ?
I can’t seem to find the right syntax.
vzorglub
(Vincent Regaud)
January 13, 2019, 10:54pm
#15
rkrisi
(Kristof Rado)
January 14, 2019, 12:27pm
#16
Sure.
@vzorglub this can be a confusing I think. This is not really a transformation, it is a ‘function’ of the binding.
This is how mine looks like
mikael
(Mikaël)
January 14, 2019, 3:46pm
#17
Thanks, it works with your configuration !
mikael
(Mikaël)
January 14, 2019, 3:47pm
#18
Thanks !
I was looking how to use “incoming value transformation”, but it turned out to easier by just entering on/open and off/closed values.
rkrisi
(Kristof Rado)
January 14, 2019, 4:21pm
#19
I’m glad! Hope that soon Shelly add more MQTT topics to each device (like RSSI and other things).
Steve_J
(Steve Janzen)
March 8, 2019, 2:43pm
#20
Hi I have the same configuration but I cant get my shelly to switch… Am I missing something. Please help
