Hi all,
I am running OH 5.1.0 M2 as docker on my NAS and I tried to setup the autoOff timer for my Shelly Plus Plug S to switch off the plug after a certain amount of time. Find below my thing and item definition and below the two test cases
- Change on the Shelly web UI gets pushed successfully to OH
- Change in OH does not get pushed to Shelly device
Thing definition:
Thing shelly:shellyplusplug:08F9E0FE1244 "Shelly PlugS Plus 2" [deviceIp="10.10.10.1", userId="", password="", eventsSwitch=true, eventsButton=true, eventsSensorReport=true]
Item defintions:
Switch ShPPs_2rel "Shelly PlugS Plus 2" (gShelly) {channel="shelly:shellyplusplug:08F9E0FE1244:relay#output"}
Number:Power ShPPs_2pow "Shelly PlugS Plus 2 Watt [%.1f %unit%]" (gShelly) {channel="shelly:shellyplusplug:08F9E0FE1244:meter#currentWatts"}
Number ShPPs_2ttime "Timer [%.0f] Minutes" (gShelly)
Number ShPPs_2aoff "Shelly PlugS Plus 2 AutoOff Timer [%.0f]" (gShelly) {channel="shelly:shellyplusplug:08F9E0FE1244:relay#autoOff"}
String ShPPs_2tactive "Shelly PlugS Plus 2 Switch [%s]" (gShelly) {channel="shelly:shellyplusplug:08F9E0FE1244:relay#timerActive"}
Log debug output from successful change on Shelly device pushing data to OH (~ 21:09):
21:09:57.905 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplugs-08f9e0fe1244: Channel relay#autoOff updated with 15 s (type class org.openhab.core.library.types.QuantityType).
21:09:57.907 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ShPPs_2aoff' changed from 55 to 15 (source: org.openhab.core.thing$shelly:shellyplusplug:08F9E0FE1244:relay#autoOff)
21:09:57.938 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplusplugs-08f9e0fe1244: NotifyStatus update received: {"id":2031533108,"src":"shellyplusplugs-08f9e0fe1244","dst":"openhab-172.17.0.3","params":{"ble":{},"cloud":{"connected":false},"mqtt":{"connected":false},"sys":{"mac":"08F9E0FE1244","restart_required":false,"time":"21:09","unixtime":1762027797,"uptime":14974,"ram_size":265528,"ram_free":117160,"fs_size":393216,"fs_free":118784,"cfg_rev":18,"available_updates":{},"webhook_rev":0},"wifi":{"sta_ip":"192.168.178.176","status":"got ip","ssid":"IoT","rssi":-57},"switch:0":{"id":0,"source":"timer","output":false,"apower":0.0,"voltage":0.0,"current":0.0,"aenergy":{"total":0.399,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027740},"temperature":{"tC":36.3,"tF":97.3}}},"result":{"ble":{},"cloud":{"connected":false},"mqtt":{"connected":false},"sys":{"mac":"08F9E0FE1244","restart_required":false,"time":"21:09","unixtime":1762027797,"uptime":14974,"ram_size":265528,"ram_free":117160,"fs_size":393216,"fs_free":118784,"cfg_rev":18,"available_updates":{},"webhook_rev":0},"wifi":{"sta_ip":"192.168.178.176","status":"got ip","ssid":"IoT","rssi":-57},"switch:0":{"id":0,"source":"timer","output":false,"apower":0.0,"voltage":0.0,"current":0.0,"aenergy":{"total":0.399,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027740},"temperature":{"tC":36.3,"tF":97.3}}}}
21:10:00.028 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1pm-441793a6c0e0: NotifyStatus update received: {"src":"shellyplus1pm-441793a6c0e0","dst":"openhab-172.17.0.3","method":"NotifyStatus","params":{"ts":1.7620278E9,"switch:0":{"id":0,"aenergy":{"total":597734.82,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027800}}}}
21:10:00.037 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplusplugs-08f9e0fe1244: NotifyStatus update received: {"src":"shellyplusplugs-08f9e0fe1244","dst":"openhab-172.17.0.3","method":"NotifyStatus","params":{"ts":1.7620278E9,"switch:0":{"apower":0.0,"voltage":0.0,"current":0.0,"aenergy":{"total":0.399,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027800}}}}
openhab>
Log debug output from failed change in OH not being pushed to the Shelly device ( ~21:11) :
21:11:16.661 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ShPPs_2aoff' changed from 15 to 30
21:11:21.217 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Buderus_DatumUhrzeit' changed from 01.11.2026 21:09 to 01.11.2026 21:10 (source: org.openhab.core.thing$mqtt:homeassistant:mySecureBroker:ems_2Desp_2Dbud_2Dthermostat:thermostat_datetime)
21:11:23.049 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Status update triggered thing initialization
21:11:23.049 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Status update triggered thing initialization
21:11:23.049 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Start initializing for thing Shelly 1 GH Ventil, type shelly1, Device address 192.168.178.185, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:11:23.049 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Start initializing for thing Shelly Plug S1 GH Pumpe, type shellyplugs, Device address 192.168.178.181, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:11:23.049 [WARN ] [b.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler tried updating the thing status although the handler was already disposed.
21:11:23.254 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplug-e86beaeb25e4: Status update triggered thing initialization
21:11:23.254 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Status update triggered thing initialization
21:11:23.255 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplug-e86beaeb25e4: Start initializing for thing Shelly PlugS Plus 1, type shellyplusplug, Device address 192.168.178.175, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:11:23.255 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Start initializing for thing ShellyPro 3 Heizstab, type shellypro3, Device address 192.168.178.186, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:11:23.255 [WARN ] [b.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler tried updating the thing status although the handler was already disposed.
openhab>
And here is all DEUG outputs around the two tests if I missed something in the above logs:
21:09:57.905 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplusplugs-08f9e0fe1244: BLU Gateway support is disabled for this device
21:10:20.038 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Status update triggered thing initialization
21:10:20.038 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Status update triggered thing initialization
21:10:20.039 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Start initializing for thing Shelly 1 GH Ventil, type shelly1, Device address 192.168.178.185, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:10:20.039 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Start initializing for thing Shelly Plug S1 GH Pumpe, type shellyplugs, Device address 192.168.178.181, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:10:20.242 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Status update triggered thing initialization
21:10:20.242 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplug-e86beaeb25e4: Status update triggered thing initialization
21:10:20.243 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplug-e86beaeb25e4: Start initializing for thing Shelly PlugS Plus 1, type shellyplusplug, Device address 192.168.178.175, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:10:20.243 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Start initializing for thing ShellyPro 3 Heizstab, type shellypro3, Device address 192.168.178.186, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:10:23.252 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - Shelly PlugS Plus 1: Closing Rpc API (socket is disconnected, discovery=false)
21:10:23.252 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - ShellyPro 3 Heizstab: Closing Rpc API (socket is disconnected, discovery=false)
21:10:38.230 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Status update triggered thing initialization
21:10:38.230 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Start initializing for thing ShellyPro 3 Heizstab, type shellypro3, Device address 192.168.178.186, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:10:38.271 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Status update triggered thing initialization
21:10:38.271 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Start initializing for thing Shelly Plug S1 GH Pumpe, type shellyplugs, Device address 192.168.178.181, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:10:38.295 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Status update triggered thing initialization
21:10:38.295 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Start initializing for thing Shelly 1 GH Ventil, type shelly1, Device address 192.168.178.185, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:10:41.238 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - ShellyPro 3 Heizstab: Closing Rpc API (socket is disconnected, discovery=false)
21:10:49.204 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1pm-68c63afaec92: Channel meter#currentWatts updated with 3.83 W (type class org.openhab.core.library.types.QuantityType).
21:10:49.256 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyem-485519d76ad7: Channel meter1#currentWatts updated with 2.25 W (type class org.openhab.core.library.types.QuantityType).
21:10:49.338 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyem-485519d95a84: Channel meter1#currentWatts updated with 4.35 W (type class org.openhab.core.library.types.QuantityType).
21:10:51.547 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-51da76: Channel meter#currentWatts updated with 1.64 W (type class org.openhab.core.library.types.QuantityType).
21:11:00.027 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1pm-441793a6c0e0: NotifyStatus update received: {"src":"shellyplus1pm-441793a6c0e0","dst":"openhab-172.17.0.3","method":"NotifyStatus","params":{"ts":1.76202786E9,"switch:0":{"id":0,"aenergy":{"total":597734.82,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027860}}}}
21:11:00.036 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplusplugs-08f9e0fe1244: NotifyStatus update received: {"src":"shellyplusplugs-08f9e0fe1244","dst":"openhab-172.17.0.3","method":"NotifyStatus","params":{"ts":1.76202786E9,"switch:0":{"apower":0.0,"voltage":0.0,"current":0.0,"aenergy":{"total":0.399,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027860}}}}
21:11:26.264 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - Shelly PlugS Plus 1: Closing Rpc API (socket is disconnected, discovery=false)
21:11:26.264 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - ShellyPro 3 Heizstab: Closing Rpc API (socket is disconnected, discovery=false)
21:11:41.241 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Status update triggered thing initialization
21:11:41.242 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Start initializing for thing ShellyPro 3 Heizstab, type shellypro3, Device address 192.168.178.186, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:11:41.280 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Status update triggered thing initialization
21:11:41.281 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Start initializing for thing Shelly Plug S1 GH Pumpe, type shellyplugs, Device address 192.168.178.181, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:11:41.303 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Status update triggered thing initialization
21:11:41.304 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Start initializing for thing Shelly 1 GH Ventil, type shelly1, Device address 192.168.178.185, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:11:44.251 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - ShellyPro 3 Heizstab: Closing Rpc API (socket is disconnected, discovery=false)
21:11:49.252 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1pm-68c63afaec92: Channel meter#currentWatts updated with 3.80 W (type class org.openhab.core.library.types.QuantityType).
21:11:49.352 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyem-485519d76ad7: Channel meter1#currentWatts updated with 2.62 W (type class org.openhab.core.library.types.QuantityType).
21:11:49.397 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyem-485519d95a84: Channel meter1#currentWatts updated with 4.06 W (type class org.openhab.core.library.types.QuantityType).
21:11:51.605 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-51da76: Channel meter#currentWatts updated with 1.58 W (type class org.openhab.core.library.types.QuantityType).
21:12:00.030 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1pm-441793a6c0e0: NotifyStatus update received: {"src":"shellyplus1pm-441793a6c0e0","dst":"openhab-172.17.0.3","method":"NotifyStatus","params":{"ts":1.76202792E9,"switch:0":{"id":0,"aenergy":{"total":597734.82,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027920}}}}
21:12:00.033 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplusplugs-08f9e0fe1244: NotifyStatus update received: {"src":"shellyplusplugs-08f9e0fe1244","dst":"openhab-172.17.0.3","method":"NotifyStatus","params":{"ts":1.76202792E9,"switch:0":{"apower":0.0,"voltage":0.0,"current":0.0,"aenergy":{"total":0.399,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027920}}}}
21:12:26.058 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Status update triggered thing initialization
21:12:26.058 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Status update triggered thing initialization
21:12:26.058 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Start initializing for thing Shelly Plug S1 GH Pumpe, type shellyplugs, Device address 192.168.178.181, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:12:26.058 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Start initializing for thing Shelly 1 GH Ventil, type shelly1, Device address 192.168.178.185, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:12:26.266 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplug-e86beaeb25e4: Status update triggered thing initialization
21:12:26.266 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Status update triggered thing initialization
21:12:26.266 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplug-e86beaeb25e4: Start initializing for thing Shelly PlugS Plus 1, type shellyplusplug, Device address 192.168.178.175, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:12:26.266 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Start initializing for thing ShellyPro 3 Heizstab, type shellypro3, Device address 192.168.178.186, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:12:29.274 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - ShellyPro 3 Heizstab: Closing Rpc API (socket is disconnected, discovery=false)
21:12:29.275 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - Shelly PlugS Plus 1: Closing Rpc API (socket is disconnected, discovery=false)
21:12:44.254 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Status update triggered thing initialization
21:12:44.255 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Start initializing for thing ShellyPro 3 Heizstab, type shellypro3, Device address 192.168.178.186, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:12:44.291 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Status update triggered thing initialization
21:12:44.292 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Start initializing for thing Shelly Plug S1 GH Pumpe, type shellyplugs, Device address 192.168.178.181, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:12:44.313 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Status update triggered thing initialization
21:12:44.314 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Start initializing for thing Shelly 1 GH Ventil, type shelly1, Device address 192.168.178.185, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:12:47.263 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - ShellyPro 3 Heizstab: Closing Rpc API (socket is disconnected, discovery=false)
21:12:49.351 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1pm-68c63afaec92: Channel meter#currentWatts updated with 3.90 W (type class org.openhab.core.library.types.QuantityType).
21:12:49.407 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyem-485519d76ad7: Channel meter1#currentWatts updated with 2.58 W (type class org.openhab.core.library.types.QuantityType).
21:12:49.450 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyem-485519d95a84: Channel meter1#currentWatts updated with 4.09 W (type class org.openhab.core.library.types.QuantityType).
21:12:51.837 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-51da76: Channel meter#currentWatts updated with 1.65 W (type class org.openhab.core.library.types.QuantityType).
21:13:00.033 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1pm-441793a6c0e0: NotifyStatus update received: {"src":"shellyplus1pm-441793a6c0e0","dst":"openhab-172.17.0.3","method":"NotifyStatus","params":{"ts":1.76202798E9,"switch:0":{"id":0,"aenergy":{"total":597734.82,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027980}}}}
21:13:00.036 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - shellyplusplugs-08f9e0fe1244: NotifyStatus update received: {"src":"shellyplusplugs-08f9e0fe1244","dst":"openhab-172.17.0.3","method":"NotifyStatus","params":{"ts":1.76202798E9,"switch:0":{"apower":0.0,"voltage":0.0,"current":0.0,"aenergy":{"total":0.399,"by_minute":[0.0,0.0,0.0],"minute_ts":1762027980}}}}
21:13:29.069 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Status update triggered thing initialization
21:13:29.069 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Status update triggered thing initialization
21:13:29.069 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Start initializing for thing Shelly 1 GH Ventil, type shelly1, Device address 192.168.178.185, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:13:29.069 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Start initializing for thing Shelly Plug S1 GH Pumpe, type shellyplugs, Device address 192.168.178.181, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:13:29.277 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplug-e86beaeb25e4: Status update triggered thing initialization
21:13:29.277 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Status update triggered thing initialization
21:13:29.277 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplusplug-e86beaeb25e4: Start initializing for thing Shelly PlugS Plus 1, type shellyplusplug, Device address 192.168.178.175, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:13:29.277 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Start initializing for thing ShellyPro 3 Heizstab, type shellypro3, Device address 192.168.178.186, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:13:32.288 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - Shelly PlugS Plus 1: Closing Rpc API (socket is disconnected, discovery=false)
21:13:32.288 [DEBUG] [ng.shelly.internal.api2.Shelly2ApiRpc] - ShellyPro 3 Heizstab: Closing Rpc API (socket is disconnected, discovery=false)
21:13:47.267 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Status update triggered thing initialization
21:13:47.267 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellypro3-ec626089ea98: Start initializing for thing ShellyPro 3 Heizstab, type shellypro3, Device address 192.168.178.186, Gen2: true, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: false
21:13:47.304 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Status update triggered thing initialization
21:13:47.304 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplugs-6a6278: Start initializing for thing Shelly Plug S1 GH Pumpe, type shellyplugs, Device address 192.168.178.181, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:13:47.322 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Status update triggered thing initialization
21:13:47.322 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly1-98f4abf2497c: Start initializing for thing Shelly 1 GH Ventil, type shelly1, Device address 192.168.178.185, Gen2: false, isBlu: false, alwaysOn: true, hasBattery: false, CoIoT: true
21:13:48.471 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyplus1pm-441793a6c0e0: Channel meter#currentWatts updated with 0.20 W (type class org.openhab.core.library.types.QuantityType).
openhab>
I would be happy if someone has an idea what is going wrong, why it only works in one direction
Cheers Justus
