I try to do a simple calculation: subtract a number from another number.
I have the following code as a rule
rule "Energy received"
Item Energy_received_message changed
var Number Pplus_ = 5.0
var Number Pminus_ = 1.0
var Number Pdiff_ = Pplus_ - Pminus_
logInfo('rule', curstate.toString)
val String json = (Energy_received_message.state as StringType).toString
logInfo('rule', json)
var Number Pplus = transform("JSONPATH", "$.Pplus", json)
logInfo('rule Pplus', Pplus)
var Number Pminus = transform("JSONPATH", "$.Pminus", json)
logInfo('rule Pminus', Pminus)
var Number Pdiff = Pplus - Pminus
logInfo('rule: Pdiff', Pdiff.toString)
Power.postUpdate(Pplus.toString)
Power2.postUpdate(Pminus.toSTring)
Power3.postUpdate(Pdiff)
This gives the following output in my log file
2018-12-27 00:51:04.261 [INFO ] [.eclipse.smarthome.model.script.rule] - 4.0
2018-12-27 00:51:04.283 [INFO ] [.eclipse.smarthome.model.script.rule] - {“Gas”: 283.934, “Date-time_stamp”: “181227005035W”, “Pminus”: 0, “Pplus”: 281}
2018-12-27 00:51:04.301 [INFO ] [se.smarthome.model.script.rule Pplus] - 281
2018-12-27 00:51:04.318 [INFO ] [e.smarthome.model.script.rule Pminus] - 0
2018-12-27 00:51:04.329 [ERROR] [.script.engine.ScriptExecutionThread] - Rule ‘Energy received’: An error occured during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.lib.NumberExtensions.operator_minus(java.lang.Number,java.lang.Number) on instance: null
As you can see, as soon as I work with hard coded values, it seems to work, but when I use values coming from a JSON string, failures occur. The failing line is: var Number Pdiff = Pplus - Pminus
What am I doing wrong?
