I am using pushover to send notifications to my android device but for some reason if statements will not work
what so ever. what am I missing?
this code here works:
rule "Enable/Disable Alarm"
Item Arm_Alarm changed to ON
sendPushoverMessage(pushoverBuilder("Kitchen Door Opened").withEmergencyPriority())
This does not work for some reason:
if (XiaomiSensorKitchen_OpenStatus.state == OPEN){
Am I missing some sort of Import or have I forgotten to enable something in a config file somewhere?
Perhaps this isnāt going to do what you expect. It isnāt an āalarmā for the kitchen door. The rule runs only once when āArmā is turned on, checks if the kitchen door is open at that time, and messages if so.
Did you mean to have a rule that runs when the door is opened, checks to see if the alam is armed, and messages if so?
Item XiaomiSensorKitchen_OpenStatus changed from CLOSED or
Item XiaomiSensorFrontDoor_OpenStatus changed from CLOSED
if(Arm_Alarm.state == ON)
if(XiaomiSensorKitchen_OpenStatus.state == OPEN){
}else if(XiaomiSensorFrontDoor_OpenStatus.state == OPEN){
sendPushoverMessage(pushoverBuilder("Front Door Opened").withEmergencyPriority())
Item XiaomiSensorKitchen_OpenStatus changed to OPEN or
Item XiaomiSensorFrontDoor_OpenStatus changed to OPEN
if(Arm_Alarm.state == ON) {
val String doorName = triggeringItem.name.toString.split("_").get(0).substring(12) // returns "Kitchen or FrontDoor"
sendPushoverMessage(pushoverBuilder(doorName + " Door Opened").withEmergencyPriority())
