No matter what I’m doing, the timer is never triggered.
I don’t see anything suspicious on the log either. I have no idea how to debug this. It appears to simply do nothing, without any indication as of why.
I also tried other, more complex triggers, where I use cancel, and define a global variable to store the timer.
I already spent hours trying to debug this, but couldn’t find any solution to the problem.
Thanks. Tried that already, also didn’t work.
This is what I have now.
var Timer myTimer = null
rule "Test timers"
Item Test received command
logInfo("timer", "hello")
myTimer = createTimer(now.plusSeconds(5)) [|
logInfo("timer", "world")
Are there any errors in the logs at all? Even if they don’t seem relevant they could be.
There is nothing apparent wrong with the lambda. I prefer to define the lambda inside the parens since it really is an argument passed to createTimer, but what you have should be fine.
I have timers like that all over the place and they work fine and I’ve seen no other reports of Timers not working, particularly with a months old version like the 2.4 release.
You only need to assign the Timer to a variable like myTimer if you want to interact with it later (e.g. cancel it). It is not required for the Timer to run.
I really don’t know what else to try to figure out why this isn’t working. You do have an alternative though with Design Pattern: Expire Binding Based Timers. But the fact that this doesn’t work is concerning.
Thanks!
I checked the log files. There is nothing suspicious in there. That’s the log output from around a minuter after the “hello” part of my rule got logged.
23:12:41.860 [INFO ] [.eclipse.smarthome.model.script.timer] - hello
23:12:43.529 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_noise' received command 48.014707380971316
23:12:43.530 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_noise changed from 77.63732812878308 to 48.014707380971316
23:12:43.868 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 809 to 810
23:12:46.679 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_AmbientLight changed from 2.07 to 3.14
23:12:47.379 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_Humidity' received command 33.375
23:12:47.380 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_Humidity changed from 33.31 to 33.375
23:12:49.927 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 810 to 811
23:12:50.937 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'hue:0106:001788281884:11' has been updated.
23:12:50.987 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_pm_10' received command 9.0
23:12:50.988 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_pm_10 changed from 8.0 to 9.0
23:12:50.991 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_pm_25' received command 9.0
23:12:50.994 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_pm_100' received command 9.0
23:13:01.329 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_Humidity' received command 33.435
23:13:01.329 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_Humidity changed from 33.375 to 33.435
23:13:02.047 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 811 to 812
23:13:04.067 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 812 to 813
23:13:10.128 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 813 to 814
23:13:12.243 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 814 to 815
23:13:21.000 [INFO ] [smarthome.event.ItemStateChangedEvent] - Computer_Sensor_CPUTemp changed from 36.0 to 33.0
23:13:21.829 [INFO ] [smarthome.event.ItemStateChangedEvent] - Network_DataSent changed from 735405 to 735429
23:13:21.830 [INFO ] [smarthome.event.ItemStateChangedEvent] - Computer_CPU_Uptime changed from 24654.6 to 24655.6
23:13:25.058 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_Humidity' received command 33.535
23:13:25.059 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_Humidity changed from 33.435 to 33.535
23:13:27.216 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_AmbientLight changed from 3.14 to 3.41
23:13:27.223 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_Barometer changed from 977.664 to 977.651
23:13:27.886 [INFO ] [smarthome.event.ItemStateChangedEvent] - fboxWanTotalGbReceived changed from 828070968193 to 828076469062
23:13:27.887 [INFO ] [smarthome.event.ItemStateChangedEvent] - fboxWanTotalGbSent changed from 58975942816 to 58976360485
23:13:28.441 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 815 to 816
23:13:30.382 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_Humidity' received command 33.614999999999995
23:13:30.383 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_Humidity changed from 33.535 to 33.614999999999995
23:13:40.562 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 816 to 817
23:13:40.988 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_pm_10' received command 9.0
23:13:40.991 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_pm_25' received command 10.0
23:13:40.992 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_pm_25 changed from 9.0 to 10.0
23:13:40.995 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_pm_100' received command 10.0
23:13:40.996 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_pm_100 changed from 9.0 to 10.0
23:13:43.527 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_noise' received command 52.00285609777402
23:13:43.527 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_noise changed from 48.014707380971316 to 52.00285609777402
23:13:51.001 [INFO ] [smarthome.event.ItemStateChangedEvent] - Computer_Sensor_CPUTemp changed from 33.0 to 36.0
23:13:51.059 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TF_Humidity' received command 33.695
23:13:51.060 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_Humidity changed from 33.614999999999995 to 33.695
23:13:56.723 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 817 to 818
23:13:58.742 [INFO ] [smarthome.event.ItemStateChangedEvent] - TF_CO2 changed from 818 to 819
Do I need to enable debug mode output somewhere? Or will there not be any extra information there?
Could this be related to other bindings? Would it help if I tried to disable some of them to figure out if they cause any issues?
@rlkoshak - The link you send is very useful, thank you very much! I can try to use that as a workaround. However, please let me know if there is anything else I can try to help debug the cause of the Timer issue.
@rossko57 - I do have a bunch of stack traces with quartz in the log, but they are likely older:
2019-03-21 20:56:27.244 [WARN ] [caldav.internal.job.EventReloaderJob] - Parser exception parsing ics file: b0709309-47bf-44d5-a38f-425423727602
net.fortuna.ical4j.data.ParserException: Error at line 14:Cannot set timezone for UTC properties
at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:143) ~[235:org.openhab.io.caldav:1.13.0]
at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:198) ~[235:org.openhab.io.caldav:1.13.0]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:339) ~[235:org.openhab.io.caldav:1.13.0]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:320) [235:org.openhab.io.caldav:1.13.0]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:137) [235:org.openhab.io.caldav:1.13.0]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.UnsupportedOperationException: Cannot set timezone for UTC properties
at net.fortuna.ical4j.model.property.UtcProperty.setTimeZone(UtcProperty.java:94) ~[?:?]
at net.fortuna.ical4j.data.CalendarBuilder.updateTimeZone(CalendarBuilder.java:353) ~[?:?]
at net.fortuna.ical4j.data.CalendarBuilder.access$300(CalendarBuilder.java:68) ~[?:?]
at net.fortuna.ical4j.data.CalendarBuilder$ContentHandlerImpl.parameter(CalendarBuilder.java:278) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$ParameterParser.parse(CalendarParserImpl.java:328) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$ParameterParser.access$1700(CalendarParserImpl.java:283) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$ParameterListParser.parse(CalendarParserImpl.java:271) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.parse(CalendarParserImpl.java:208) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.access$1100(CalendarParserImpl.java:190) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyListParser.parse(CalendarParserImpl.java:173) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$ComponentParser.parse(CalendarParserImpl.java:383) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$ComponentParser.access$900(CalendarParserImpl.java:367) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyListParser.parse(CalendarParserImpl.java:171) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:122) ~[?:?]
... 6 more
They seem to be related to the " CalDAV Binding (personal)" binding I’m using.
Note that the stacktrace I posted is the latest one I received, and it’s from a couple of hours ago, but it happened after the last restart I did.
Since I had problems with that binding before, I actually tried uninstalling it for a while, but the problem didn’t go away.
Perhaps it’s worth trying that again? Would that help?
Unexpectedly spiteful knock-on effect, somehow the caldav is messing with scheduling? I wonder if the timers will eventually go off in a different timezone - maybe now() has got wrong.
It’s muttering about timezone and parsing, so I’d guess its a parameter error of some kind.
