[SOLVED] Sitemap always shows state of switch
if have a switch (with custom dynamic item which works):
Switch Keymatic_State "Haustür" <keymatic> {channel="homematic:HM-Sec-Key:ccu2:XXXXXXXXXX:1#STATE"}
and a mapping in the sitemap:
Switch item=Keymatic_State label="Haustür" mappings=[ON="Offen",OFF="Verschlossen"]
My Problem: the stateformat is shown in basicui (and also in the app):
What can i do? :thinking:
Greetings,
Skibi
Put empty square brackets in the label in your sitemap. E.g. label=“Hastür
Thanks! That solved the problem. :+1:
Was this a change in 2.4? I only noticed that the switch state was displayed in my sitemap when I upgraded from 2.3 to 2.4. My issue is that I used the label in the item definition and not in the sitemap.
So I had:
Switch DoorLock “Lock (upper) [MAP(lock.map):%s]” { channel=“zwave:device:2a2bd030:node5:lock_door” }
with sitemap
  	Switch item=DoorLock
With the above solution it seems I now have to define the label in my sitemap if I don’t want the switch state to show.
