Below is the error I get with the below sitemap. it has worked before. am i missing something?
2.1 install updated to 2.2 do I need to clean something?
13:35:03.868 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model ‘default.sitemap’
13:35:03.944 [WARN ] [del.core.internal.ModelRepositoryImpl] - Configuration model ‘default.sitemap’ has errors, therefore ignoring it: [1,17]: mismatched input ‘label’ expecting ‘{’
sitemap default label = "TheNet" {
Frame label = "TotalEnergy" {
Text label = "TotalEnergy" {
Text item = TotalEnergy label = "Total Energy [%.2f W]" icon = "energy"
Text item = emontxshield_ct1 icon = "firstfloor"
Text item = emontxshield_ct2 icon = "firstfloor"
Text item = emontxshield_vrms icon = "energy"
Text item = emontxshield_rssi icon = "energy"
Image icon = "energy" url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=TotalEnergy&period=D"
Image icon = "energy" url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=emontxshield_ct1,emontxshield_ct2&period=D"
Image icon = "energy" url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=emontxshield_vrms&period=H"
Image icon = "energy" url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=emontxshield_rssi&period=H"
Frame label = "Inside/Outside Temp/Hum" {
Text label = "In/Out Temp/Hum" icon = "weather" {
Image url = "http://guest:guest@10.1.1.8:8080/chart?groups=gInOutTemp&period=M&random=1&h=400&w=1200"
Image url = "http://guest:guest@10.1.1.8:8080/chart?groups=gInOutHum&period=M&random=1&h=400&w=1200"
Frame label = "Astro" icon = "sun_clouds" {
Text label = "Current Status" {
Text item = Sunrise_Time icon = "sunrise"
Text item = Sunset_Time icon = "sunset"
Text item = Sun_Elevation icon = "sunmoon"
Text item = Moon_Elevation icon = "sunmoon"
Text item = Moon_Phase_Name
Text item = Moon_Zodiac_Sign icon = "zodiac"
Text label = "Weather forecast" {
Text label = "forecast..." icon = "sun_clouds"
Frame item = Weather_Temperature label = "Weather" {
Text label = "Weather " icon = "energy" {
Webview url = "/weather-data?locationId=home&layout=example&iconset=colorful" height = 13
Text item = Weather_LastUpdate valuecolor = [Weather_LastUpdate > 120 = "orange", Weather_LastUpdate > 300 = "red"] visibility = [Weather_LastUpdate > 30]
Text item = Weather_Temperature valuecolor = [Weather_LastUpdate == Uninitialized = "gray", Weather_LastUpdate > 90 = "gray", > 77 = "orange", > 60 = "green", > 40 = "aqua", <= 40 = "blue"] {
Frame {
Text item = Weather_Temp_Max
Text item = Weather_Temp_Min
Frame {
Switch item = Weather_Chart_Period label = "Period" mappings = [0 = "Hour", 1 = "Day", 2 = "Week"]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Temperature,Weather_Temp_Max,Weather_Temp_Min&period=h" visibility = [Weather_Chart_Period == 0, Weather_Chart_Period == Uninitialized]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Temperature,Weather_Temp_Max,Weather_Temp_Min&period=D" visibility = [Weather_Chart_Period == 1]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Temperature,Weather_Temp_Max,Weather_Temp_Min&period=W" visibility = [Weather_Chart_Period == 2]
Text item = Weather_Humidity {
Frame {
Switch item = Weather_Humidity_Chart_Period label = "Period" mappings = [0 = "Hour", 1 = "Day", 2 = "Week"]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Humidity&period=h" visibility = [Weather_Humidity_Chart_Period == 0, Weather_Humidity_Chart_Period == Uninitialized]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Humidity&period=D" visibility = [Weather_Humidity_Chart_Period == 1]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Humidity&period=W" visibility = [Weather_Humidity_Chart_Period == 2]
Text item = Weather_Pressure {
Frame {
Switch item = Weather_Pressure_Chart_Period label = "Period" mappings = [0 = "Hour", 1 = "Day", 2 = "Week"]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Pressure&period=h" visibility = [Weather_Pressure_Chart_Period == 0, Weather_Pressure_Chart_Period == Uninitialized]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Pressure&period=D" visibility = [Weather_Pressure_Chart_Period == 1]
Image url = "http://guest:guest@10.1.1.8:8080/rrdchart.png?items=Weather_Pressure&period=W" visibility = [Weather_Pressure_Chart_Period == 2]
Frame label = "LED Light"
icon = "light" {
Switch item = Light_Groundfloor mappings = [DECREASE = '-', INCREASE = '+']
Switch item = Light_LivingroomB
Frame label = "ZWave"
icon = "light" {
Switch item = Front_Door_Lock label = "Front door lock control"
Text item = Front_Door_Basic label = "Front door lock status [%s]"
Text item = Front_Door_Battery label = "Front door lock battery level [%d %%]"
Switch item = GarageDoorLockStatus label = "Garage Door Deadbolt" icon = "door"
Text item = GarageDoorLockBatteryLevel label = "Garage Door Battery" icon = "energy"
Switch item = BackDoorLockStatus label = "Back Door Deadbolt" icon = "door"
Switch item = MasterBedroomLightStatus label = "Master Bedroom Light"
Switch item = LaundryRoomLightStatus label = "Laundry Room Light"
Switch item = OutdoorFrontLightStatus label = "Front Porch Light"
Switch item = LivingroomPlugStatus label = "Livingroom Door plug" icon = "energy"
Switch item = UpstairsHallPlugStatus label = "Upstairs Hall plug" icon = "energy"
Frame label = "X10 Switch"
icon = "light" {
Switch item = x10SwitchP1 label = "Lamp Switch"
Switch item = x10SwitchP2 label = "Toggle Switch"
Switch item = x10SwitchA1 label = "Upstairs Stereo"
Switch item = x10SwitchA2 label = "Hall Light"
Switch item = x10SwitchA3 label = "Living Halogen"
Switch item = x10SwitchJ1 label = "Jenns Light"
Switch item = x10SwitchK1 label = "Kitchen Light"
Frame label = "Garage Door"
icon = "light" {
Switch item = GarageDoorSwitch icon = "garagedoor"
Text item = GarageDoorString icon = "garagedoor"
Text item = GarageDoorContact icon = "garagedoor"
Switch item = GarageDoorShutter icon = "garagedoor"
Frame label = "Dining Room Thermostat" {
Text item = NestThermostatCurrentTemperature visibility = [upstairs_hall_temperature_scale == "F"]
Text item = upstairs_hall_ambient_temperature_c visibility = [upstairs_hall_temperature_scale == "C"]
Text item = upstairs_hall_humidity
Switch item = upstairs_hall_hvac_mode mappings = [heat = "Heat", cool = "Cool", off = "Off"]
Text item = upstairs_hall_away_temperature_low_f visibility = [home_away == "away", home_away == "auto-away"]
Text item = upstairs_hall_away_temperature_high_f visibility = [home_away == "away", home_away == "auto-away"]
Setpoint item = upstairs_hall_target_temperature_f label = "Target Temperature [%.1f °F]" minValue = 50 maxValue = 80 step = 1 visibility = [upstairs_hall_hvac_mode == "heat", upstairs_hall_hvac_mode == "cool"]
Setpoint item = upstairs_hall_target_temperature_low_f label = "Minimum Temperature [%.1f °F]" minValue = 50 maxValue = 80 step = 1 visibility = [upstairs_hall_hvac_mode == "heat-cool"]
Setpoint item = upstairs_hall_target_temperature_high_f label = "Maximum Temperature [%.1f °F]" minValue = 50 maxValue = 80 step = 1 visibility = [upstairs_hall_hvac_mode == "heat-cool"]
Text item = upstairs_hall_last_connection
Frame label = "Basement Nest Protect" {
Text item = basement_smoke valuecolor = [basement_state == "green" = "green", basement_state == "gray" = "gray", basement_state == "yellow" = "yellow", basement_state == "red" = "red"]
Text item = basement_co valuecolor = [basement_state == "green" = "green", basement_state == "gray" = "gray", basement_state == "yellow" = "yellow", basement_state == "red" = "red"]
Text item = basement_last_connection
Frame label = "Upstairs Nest Protect" {
Text item = upstairs_smoke valuecolor = [upstairs_state == "green" = "green", upstairs_state == "gray" = "gray", upstairs_state == "yellow" = "yellow", upstairs_state == "red" = "red"]
Text item = upstairs_co valuecolor = [upstairs_state == "green" = "green", upstairs_state == "gray" = "gray", upstairs_state == "yellow" = "yellow", upstairs_state == "red" = "red"]
Text item = upstairs_last_connection
