Hello I have a newbie problem with sitemap not loading in the BasicUI… Its a fresh intall of OH 2.4 under Synology diskstation. Was going through tutorial and after creating my sitemap got stuck…
in the PaperUI I have defined the default sitemap as:
santariskes
Sitemap is in the openhab\conf\sitemaps\santariskes.sitemap
[WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'santariskes.sitemap' has errors, therefore ignoring it: [3,8]: required (...)+ loop did not match anything at input 'Dimmer' [5,1]: extraneous input '}' expecting EOF
if I comment out the only dimmer item I get:
[WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘santariskes.sitemap’ has errors, therefore ignoring it: [4,5]: required (…)+ loop did not match anything at input ‘}’ [5,1]: extraneous input ‘}’ expecting EOF
rossko57
Quote marks in the editor seems to be ok maybe it’s copy paste thing as you mentioned.
sihui:
You are right! first I wrote “slider” that didn’t work and gave similar error, but with “Slider” it now works. Thank you!
I took the Dimmer Item name from:
in this list I don’t see a Slider option… are there some “hiden” items? Where can I find correct item list?
Items are objects internal to openHAB, simple models of some external device or function usually. e.g. a Dimmer type.
The elements in a sitemap are just widgets you use to display or control Items. For example if you had a Dimmer type Item you might choose a switch widget to allow on/off control only, or you might choose a text widget for display only.
Slider item=myItem
Switch item=myItem
Text item=myItem
