Boby
(Robert K.)
1
I’m fighting with a strange problem: When I try to clear the pairings using this command…
smarthome:homekit clearPairings
The result is:
Command not found: smarthome:homekit
When I look up the possible commands in the console, “smarthome:homekit” is missing
What’s wrong or what can I do to make this command available?
Thank you!
Boby
(Robert K.)
2
So, finally I solved the problem. Don’t know exactly what helped, but at least I did the following:
- changing the first line in the homekit.config from … “1.0” to L"1"
- then cleaning cache & rebooting twice
Then Homekit got working again on my RPi; still fighting to
Where this file is located ?
