In binding doesn’t need protocol information(packet type and sub type) as it’s only need by the RFXCOM controller to know exactly how to transmit data. See more details from wiki
Thanks Pali,
It worked after your update + update of the “setMode” option of the rfxcom receiver config file (enable the AC protocol listening)
This parameter was set in the HABmin apps, but apparently, it is not sufficient…
I’m trying to get this to work in openhab2 but with no luck so far. According to the documentation, only lighting2 actuators are supported, not sensors.
Is there a syntax for getting this defined as an input in OH2 rfxcom?
