Yes, both. Same problems…
I’ve updated to snapshot 1729 now, but the problems are still existing.
Do I need ZWAVE devices to reproduce the problem?
Unfortunately yes. You only can add a controller manually. But the other devices are stored in controller.
Can you try raising the log level of Jersey so it shows the stacktrace of the exception resulting in the 500 error?
log:set trace org.glassfish.jersey.server
PaperUI error: 'Internal Server Error’ (500:SERVER_ERROR)
2019-10-19 14:18:04.067 [DEBUG] [ersey.server.ServerRuntime$Responder] - Starting mapping of the exception.
org.glassfish.jersey.server.internal.process.MappableException: java.lang.NullPointerException
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.mapTargetToRuntimeEx(AbstractJavaResourceMethodDispatcher.java:179) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.access$200(AbstractJavaResourceMethodDispatcher.java:72) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:149) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [23:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:542) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [90:org.eclipse.jetty.security:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.Server.handle(Server.java:505) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [83:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [83:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [83:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804) [95:org.eclipse.jetty.util:9.4.18.v20190429]
Caused by: java.lang.NullPointerException
at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionParameterDTO.<init>(EnrichedConfigDescriptionParameterDTO.java:52) ~[?:?]
at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionDTOMapper.mapEnrichedParameters(EnrichedConfigDescriptionDTOMapper.java:59) ~[?:?]
at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionDTOMapper.map(EnrichedConfigDescriptionDTOMapper.java:45) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.config.ConfigDescriptionResource.getByURI(ConfigDescriptionResource.java:110) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[?:?]
... 54 more
2019-10-19 14:18:04.081 [DEBUG] [ersey.server.ServerRuntime$Responder] - Exception 'null' has been mapped by 'org.eclipse.smarthome.io.rest.JSONResponse$ExceptionMapper' to response 'Internal Server Error' (500:SERVER_ERROR).
That looks like level DEBUG. Level TRACE may give even more useful information.
log:get
org.glassfish.jersey.server │ TRACE
It is set to TRACE!
Thanks we should be able to fix this NPE.
The EnrichedConfigDescriptionDTOMapper
was introduced with:
But it was merged on 14.10.2019, 12:51, and snapshot 1725 was build on 15.10.2019, 5:55. ??
And snapshot 1725 has allegedly not this error! Maybe it was merged later (after 1725)?
Clicking on a zwave device in HABmin:
14:46:47.670 [DEBUG] [jersey.server.ServerRuntime$Responder] - Starting mapping of the exception.
... 54 more
14:46:47.683 [DEBUG] [jersey.server.ServerRuntime$Responder] - Exception 'null' has been mapped by 'org.eclipse.smarthome.io.rest.JSONResponse$ExceptionMapper' to response 'Internal Server Error' (500:SERVER_ERROR).
NPE = Null Pointer Exception?
Yes that’s what NPE stands for! Because they are so common they are abbreviated to NPE.
The compiler can detect these at compile time when Java classes are properly annotated with null annotations. Though there’s still a lot of work todo to annotate them all.
Thanks for reporting and evaluating. I submitted a fix:
We are not talking about this. This is running (for controller settings)!
We are talking about this: Click on any zwave device, but not the controller:
Tools:(=“Werkzeuge” in german)
Controller: --> “Advanced Settings” are OK.
Any other zwave device: NOT OK
Just the menu for a non-controller device…
Not advanced…
Advanced…
However, I noticed that most of my devices are missing the configuration parameters section!
@wborn
@5iver
@chris
@cweitkamp
I’ve updated to snapshot 1731. The errors are gone !
Thanx a lot!
But there are next NPE when I open Paper UI --> Configuration --> System
See this topic….
On Snapshot or M4? Which build??
On Snapshot 1731, but they built it about 7 hours later…
I guess there were no changes in between…
