From what i can gather. the inbound rule must come before the outbound rule otherwise it turns the rest of the items into gibberish, but they still work.
The issue i have not once that is fixed is i get a warning for every item now.
2018-06-01 22:06:18.498 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2018-06-01 22:06:18.541 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:FrontDownlights in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.545 [ome.event.ItemUpdatedEvent] - Item 'FrontDownlights' has been updated.
2018-06-01 22:06:18.548 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:SprinklerSystemZone1 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.554 [ome.event.ItemUpdatedEvent] - Item 'SprinklerSystemZone1' has been updated.
2018-06-01 22:06:18.556 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:SprinklerSystemZone2 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.562 [ome.event.ItemUpdatedEvent] - Item 'SprinklerSystemZone2' has been updated.
2018-06-01 22:06:18.565 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:SprinklerSystemZone3 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.570 [ome.event.ItemUpdatedEvent] - Item 'SprinklerSystemZone3' has been updated.
2018-06-01 22:06:18.573 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:SprinklerSystemZone4 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.578 [ome.event.ItemUpdatedEvent] - Item 'SprinklerSystemZone4' has been updated.
2018-06-01 22:06:18.581 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:GarageDoor in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.586 [ome.event.ItemUpdatedEvent] - Item 'GarageDoor' has been updated.
2018-06-01 22:06:18.599 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:g_onHours1 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.604 [ome.event.ItemUpdatedEvent] - Item 'g_onHours1' has been updated.
2018-06-01 22:06:18.606 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours1_Mode in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.610 [ome.event.ItemUpdatedEvent] - Item 'onHours1_Mode' has been updated.
2018-06-01 22:06:18.612 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours1_Temp in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.618 [ome.event.ItemUpdatedEvent] - Item 'onHours1_Temp' has been updated.
2018-06-01 22:06:18.620 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours1 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.625 [ome.event.ItemUpdatedEvent] - Item 'onHours1' has been updated.
2018-06-01 22:06:18.636 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:g_onHours2 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.641 [ome.event.ItemUpdatedEvent] - Item 'g_onHours2' has been updated.
2018-06-01 22:06:18.643 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours2_Mode in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.648 [ome.event.ItemUpdatedEvent] - Item 'onHours2_Mode' has been updated.
2018-06-01 22:06:18.650 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours2_Temp in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.655 [ome.event.ItemUpdatedEvent] - Item 'onHours2_Temp' has been updated.
2018-06-01 22:06:18.657 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours2 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.662 [ome.event.ItemUpdatedEvent] - Item 'onHours2' has been updated.
2018-06-01 22:06:18.673 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:g_onHours3 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.678 [ome.event.ItemUpdatedEvent] - Item 'g_onHours3' has been updated.
2018-06-01 22:06:18.681 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours3_Mode in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.685 [ome.event.ItemUpdatedEvent] - Item 'onHours3_Mode' has been updated.
2018-06-01 22:06:18.687 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours3_Temp in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.693 [ome.event.ItemUpdatedEvent] - Item 'onHours3_Temp' has been updated.
2018-06-01 22:06:18.695 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours3 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.702 [ome.event.ItemUpdatedEvent] - Item 'onHours3' has been updated.
2018-06-01 22:06:18.714 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:g_onHours4 in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.721 [ome.event.ItemUpdatedEvent] - Item 'g_onHours4' has been updated.
2018-06-01 22:06:18.723 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours4_Mode in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.728 [ome.event.ItemUpdatedEvent] - Item 'onHours4_Mode' has been updated.
2018-06-01 22:06:18.730 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours4_Temp in ManagedMetadataProviderImpl, because it does not exists.
2018-06-01 22:06:18.735 [ome.event.ItemUpdatedEvent] - Item 'onHours4_Temp' has been updated.
2018-06-01 22:06:18.737 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:onHours4 in ManagedMetadataProviderImpl, because it does not exists.
The current items file is
// This is the items file
String Irrigation_Zone1
String Irrigation_Zone2
String Irrigation_Zone3
String Irrigation_Zone4
Switch FrontDownlights "Front Downlights" [ "Switchable" ] { mqtt="<[broker:stat/SmartHouse/Utilities/FrontDownli/POWER:state:default],>[broker:cmnd/SmartHouse/Utilities/FrontDownli/power:command:*:default]" }
Switch SprinklerSystemZone1 "Front Grass Sprinklers" [ "Switchable" ] { mqtt=">[broker:SmartHouse/Utilities/SprinklerSystem:command:ON:Z1ON],>[broker:SmartHouse/Utilities/SprinklerSystem:command:OFF:Z1OFF]" }
Switch SprinklerSystemZone2 "Front Garden Sprinklers" [ "Switchable" ] { mqtt=">[broker:SmartHouse/Utilities/SprinklerSystem:command:ON:Z2ON],>[broker:SmartHouse/Utilities/SprinklerSystem:command:OFF:Z2OFF]" }
Switch SprinklerSystemZone3 "Back Grass Sprinklers" [ "Switchable" ] { mqtt=">[broker:SmartHouse/Utilities/SprinklerSystem:command:ON:Z3ON],>[broker:SmartHouse/Utilities/SprinklerSystem:command:OFF:Z3OFF]" }
Switch SprinklerSystemZone4 "Back Garden Sprinklers" [ "Switchable" ] { mqtt=">[broker:SmartHouse/Utilities/SprinklerSystem:command:ON:Z4ON],>[broker:SmartHouse/Utilities/SprinklerSystem:command:OFF:Z4OFF]" }
Switch GarageDoor "Garage Door" [ "Switchable" ] { mqtt=">[broker:SmartHouse/Utilities/GarageDoor:command:ON:OPEN],>[broker:SmartHouse/Utilities/GarageDoor:command:OFF:CLOSE]" }
Number FrontDownlight_RSSI "Front Downlight: RSSI [%d %%]" { mqtt="<[broker:tele/SmartHouse/Utilities/FrontDownli/STATE:state:JSONPATH($.Wifi.RSSI)]" }
Number Countdown_Zone1 "Minutes Remaining [%d]"
Number Countdown_Zone2 "Minutes Remaining [%d]"
Number Countdown_Zone3 "Minutes Remaining [%d]"
Number Countdown_Zone4 "Minutes Remaining [%d]"
Switch SprinklerCycle "30 Minute Cycle"
Switch SprinklerSystemSchedule1 "Front Grass Schedule"
Switch SprinklerSystemSchedule2 "Front Garden Schedule"
Switch SprinklerSystemSchedule3 "Back Grass Schedule"
Switch SprinklerSystemSchedule4 "Back Garden Schedule"
DateTime Irrigation_StartTime1 "Zone 1 Last Watered [%1$ta %1$tR]"
DateTime Irrigation_StartTime2 "Zone 2 Last Watered [%1$ta %1$tR]"
DateTime Irrigation_StartTime3 "Zone 3 Last Watered [%1$ta %1$tR]"
DateTime Irrigation_StartTime4 "Zone 4 Last Watered [%1$ta %1$tR]"
Group g_onHours1 "Front Grass Sprinkler Minutes" [ "Thermostat" ]
Number onHours1_Mode "Front Grass Sprinkler Minutes Mode" (g_onHours1) [ "homekit:HeatingCoolingMode" ]
Number onHours1_Temp "Front Grass Sprinkler Minutes Temp" (g_onHours1) [ "CurrentTemperature" ]
Number onHours1 "Front Grass Sprinkler Minutes" (g_onHours1) [ "TargetTemperature" ]
Group g_onHours2 "Front Garden Sprinkler Minutes" [ "Thermostat" ]
Number onHours2_Mode "Front Garden Sprinkler Minutes Mode" (g_onHours2) [ "homekit:HeatingCoolingMode" ]
Number onHours2_Temp "Front Garden Sprinkler Minutes Temp" (g_onHours2) [ "CurrentTemperature" ]
Number onHours2 "Front Garden Sprinkler Minutes" (g_onHours2) [ "TargetTemperature" ]
Group g_onHours3 "Back Grass Sprinkler Minutes" [ "Thermostat" ]
Number onHours3_Mode "Back Grass Sprinkler Minutes Mode" (g_onHours3) [ "homekit:HeatingCoolingMode" ]
Number onHours3_Temp "Back Grass Sprinkler Minutes Temp" (g_onHours3) [ "CurrentTemperature" ]
Number onHours3 "Back Grass Sprinkler Minutes" (g_onHours3) [ "TargetTemperature" ]
Group g_onHours4 "Back Garden Sprinkler Minutes" [ "Thermostat" ]
Number onHours4_Mode "Back Garden Sprinkler Minutes Mode" (g_onHours4) [ "homekit:HeatingCoolingMode" ]
Number onHours4_Temp "Back Garden Sprinkler Minutes Temp" (g_onHours4) [ "CurrentTemperature" ]
Number onHours4 "Back Garden Sprinkler Minutes" (g_onHours4) [ "TargetTemperature" ]
