Hello folks,
I am continuously learning Openhab though I am not new to IOT but new to openhab.
Introduction:
I have made my openhab and sonoff devices (running Sonoff Tasmota firmware) communicating each other via MQTT. Everything is working as expected but have one issue.
Problem:
When I turn the switch ON / OFF from Basic UI. State of switch under Basic UI changes correctly. But Sonoff devices such as Sonoff Basic, also have on-device button to toggle the switch. If I toggle the switch using on-device button then state does not change under Basic UI until I refresh the page. My .items and .sitemap files are given below.
Further Information:
sonoff.items:
Group Home "Home" <house>
Group Bedroom "Bedroom" <bedroom> (Home)
Switch Bedroom_Light "Light" <light> (Bedroom, gLight) ["Lighting"] { mqtt=">[broker:cmnd/sonoff-A00EEA/POWER:command:*:default],
<[broker:stat/sonoff-A00EEA/POWER:state:default]" }
Switch Bedroom_Power "Power Outlet" <poweroutlet> (Bedroom, gPower) ["Switchable"] { mqtt=">[broker:cmnd/sonoff-A01EEA/POWER:command:*:default],
<[broker:stat/sonoff-A01EEA/POWER:state:default]" }
Group:Switch:OR(ON, OFF) gLight "Light" <light> (Home)
Group:Switch:OR(ON, OFF) gPower "Power Outlet" <poweroutlet> (Home)
sonoff.sitemap:
sitemap home label="Home" {
Frame {
Group item=Bedroom
Frame {
Text label="Light" icon="light" {
Default item=Bedroom_Light label="Bedroom"
Text label="Power Outlet" icon="poweroutlet" {
Default item=Bedroom_Power label="Bedroom"
May please someone help in this regard?
