thanks for your help. I found the error:
if (Sonoff6.state ! = 0 )
instead of:
if (Sonoff6.state !== 0 )
instead of:
Please don’t mix up things:
= -> set var to, e.g. i = 4
== -> compare the value, is it the same? e.g. if(i == 4)
=== -> compare if identical, e.g. if(i === null)
!= -> not the same value
!== not identical
So, if comparing a value to null
, you should use ===
or !==
, if comparing to a value (like 0
), you have to use ==
or !=
ok, thanks, I mark the reminder of the examples
why if I restart OH it does not update the STATE and I have to use the buttons on the wall?
What is your current configuration of items and things, relating to sonoff?
when I restart OH received this message:
[WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'mqttSonoff8state' with pattern 'JSONPATH($.Wifi.RSSI):%s %%': Invalid path '$.Wifi.RSSI' in 'NULL %'
I have no things configured in paperUi
I only entered in the item file:
Switch mqttSonoff8_1 "SOnOff 8-1 [%s]" {mqtt=">[mosquitto:cmnd/shelly-soggiorno/POWER1:command:*:${command}],<[mosquitto:stat/shelly-soggiorno/POWER1:state:REGEX((.*))]"}
Switch mqttSonoff8_2 "SOnOff 8-2 [%s]" {mqtt=">[mosquitto:cmnd/shelly-soggiorno/POWER2:command:*:${command}],<[mosquitto:stat/shelly-soggiorno/POWER2:state:REGEX((.*))]"}
String mqttSonoff8lwt "SOnOff soggiorno [%s]" {mqtt="<[mosquitto:tele/shelly-soggiorno/LWT:state:default]" }
String mqttSonoff8state "SOnOff 8 [JSONPATH($.Wifi.RSSI):%s %%]" {mqtt="<[mosquitto:tele/shelly-soggiorno/STATE:state:default]" }
Rollershutter Sonoff8 "soggiorno [%d%%]" (tapparelle,sonoff) { autoupdate="false"}
Switch tapparella_soggiorno "tapparella soggiorno " <rollershutter> (tapparelle,sonoff) [ "Switchable" ] { autoupdate="true"}
and the sitemap:
Default item=Sonoff8
Selection item=Sonoff8 mappings=[ 0="0%",25="25%",50="50%",75="75%",100="100%" ]
furthermore I noticed that with the closing percentages (25% … 50% … 75%) they do not match … example 50% and almost 75% of closure
a specification, as a broker I use mosquitto is a 1.x binding there is no need for things … right?
Jepp, if using mqtt1, there is no thing at all. In question of tele, these items will be updated with a given frequence (imho 600 seconds default). As openHAB will not ask for the current value (and mosquitto wont tell it if not retained, even if asked for…)
By the way: retain has to be set by the publisher, not the subscriber
You will have to wait until your shelly sends an update for tele/# channels
so, if I understand correctly, I have to set:
mosquitto.retain = true
because by setting poweretain on Tasmota, OH after the reboot it does not keep the last value, even waiting for the teleperiod update time (in my case it is 300)
As far as I understood, retain has to be set per topic. This is done by the publisher.
I also have other peripherals with the Tasmota firmware connected with mosquitto, and yesterday, restarting OH I realized that they also don’t receive the update and I have to do it from OH
@Udo_Hartmann: I want to use this code in Openhab2.4 mqtt2 but I don’t know how to create the Things (channels) for this two rows from Udo’s Item file:
Switch mqttSonoff6_1 "SOnOff 6-1 [%s]" {mqtt=">[mosquitto:sonoff_t6/cmnd/POWER1:command:*:${command}],<[mosquitto:sonoff_t6/stat/POWER1:state:REGEX((.*))]"}
Switch mqttSonoff6_2 "SOnOff 6-2 [%s]" {mqtt=">[mosquitto:sonoff_t6/cmnd/POWER2:command:*:${command}],<[mosquitto:sonoff_t6/stat/POWER2:state:REGEX((.*))]"}
Easy. Bridge, Thing, Channels:
Bridge mqtt:broker:mosquitto "Mosquitto" [
host="127.0.0.1", // or whatever the ip of the broker is
port=1883, // same for port
clientID="openHAB2-2" // client id of openHAB in the broker
Thing topic sonoff6 "sonoff 6" @ "mqtt" {
Channels:
Type switch : ch1 "Power" [ stateTopic= "sonoff_t6/stat/POWER1", commandTopic="sonoff_t6/cmnd/POWER1" ]
Type switch : ch2 "Power" [ stateTopic= "sonoff_t6/stat/POWER2", commandTopic="sonoff_t6/cmnd/POWER2" ]
Items:
Switch mqttSonoff6_1 "SOnOff 6-1 [%s]" { channel="mqtt:topic:mosquitto:sonoff6:ch1" }
Switch mqttSonoff6_2 "SOnOff 6-2 [%s]" { channel="mqtt:topic:mosquitto:sonoff6:ch2" }
There are several other options for the bridge, e.g. LWT, username, password… if you use the standard port (1883), you can omit this parameter, too. If you don’t set the clientID, openHAB will use a random id (and afaik it will change after restarting openHAB, so it’s better to set this parameter)
@Udo_Hartmann: Thanks. Do I need the REGEX state? With this files I see the Wifi RSSI value in my sitemap, but their is no action on the Jinvoo curtain switch if I select a % value.
Interlock 1, Setoption80 0
Or does it works also in Rollershuter mode with one thing: …[stateTopic=“stat/JalloJin6/SHUTTER1” , commandTopic=“cmnd/JalloJin6/SHUTTERPOSITION”, on=“0”, off=“100” ]? I use some of this devices with this config, but without % value.
Thing topic JalloJin6 "JalloJin 6" {
Channels:
Type switch : ch1 "Power" [ stateTopic= "JalloJin6/stat/POWER1", commandTopic="JalloJin6/cmnd/POWER1", on="ON", off="OFF" ]
Type switch : ch2 "Power" [ stateTopic= "JalloJin6/stat/POWER2", commandTopic="JalloJin6/cmnd/POWER2", on="ON", off="OFF" ]
Type string : devicestate "Jallo-Test [%s]" [ stateTopic="tele/JalloJin6/LWT" ]
Type string : wifi-rssi "Wifi RSSI" [ stateTopic="tele/JalloJin6/STATE", transformationPattern="JSONPATH:$.Wifi.RSSI" ]
Items:
```csv
Switch mqttJalloJin6_1 "JalloJin 6-1 [%s]" {channel="mqtt:topic:embedded-mqtt-broker:JalloJin6:ch1" }
Switch mqttJalloJin6_2 "JalloJin 6-2 [%s]" {channel="mqtt:topic:embedded-mqtt-broker:JalloJin6:ch2" }
String mqttJalloJin6LWT "JalloJin 6 LWT [%s]" {channel="mqtt:topic:embedded-mqtt-broker:JalloJin6:devicestate"}
String mqttJalloJin6state "JalloJin 6 WIFI [JSONPATH($.Wifi.RSSI):%s %%]" {channel="mqtt:topic:embedded-mqtt-broker:JalloJin6:wifi-rssi"}
Rollershutter JalloJin6 "JalloJin 6 [%d%%]" { autoupdate="false" }
added postcommand=“true”, OpenHab Log: Item ‘JalloJin6’ received command 50 (found it in the german forum, also written from you )
I think I have some failure in the rule that I have copied above or I have to add the “Log Debug”.
Is it correct that I have to use the following commands in the console via e.g. Putty for Openhab 2.4?
bash> openhab-cli console
openhab2> log:set DEBUG org.eclipse.smarthome.model.script.mylogger
openhab2> logout
var long intStartTime
var Timer tMqtt6 = null
var boolean lMqtt6 = false
rule "JalloJin6"
Item mqttJalloJin6_1 changed or
Item mqttJalloJin6_2 changed
logDebug("JalloJin","6: {} is {}",triggeringItem.name,triggeringItem.state)
if(triggeringItem.state==ON) {
intStartTime=now.millis
logDebug("JalloJin","6: StartTime= {}",intStartTime)
else {
val long myPercent = (now.millis - intStartTime)/200
logDebug("JalloJin","6: StopTime= {}; Duration= {}",now.millis, now.millis-intStartTime)
logDebug("JalloJin","6: Percent= {}",myPercent)
if (!(JalloJin6.state instanceof Number)) JalloJin6.postUpdate(0)
if (triggeringItem.name == "mqttJalloJin6_1") {
JalloJin6.postUpdate(if(((JalloJin6.state as Number)-myPercent) > 0 ) (JalloJin6.state as Number)-myPercent else 0)
else {
JalloJin6.postUpdate(if(((JalloJin6.state as Number)+myPercent) < 100 ) (JalloJin6.state as Number)+myPercent else 100)
rule "JalloJin6 2"
Item JalloJin6 received command
logDebug("JalloJin","6-2: received command: {}",receivedCommand)
if(receivedCommand instanceof Number) {
logDebug("JalloJin","6-2: received command is Number")
lMqtt6 = true
if(tMqtt6 !== null) tMqtt6.cancel
val Integer iDuration = (((receivedCommand as Number) - (JalloJin6.state as Number)) * if((receivedCommand as Number) > (JalloJin6.state as Number)) 200 else -200).intValue
logDebug("JalloJin","6-2: Duration: {} mSec",iDuration)
if((receivedCommand as Number) < (JalloJin6.state as Number)) {
logDebug("JalloJin","6-2: UP!")
mqttJalloJin6_1.sendCommand(ON)
else {
logDebug("JalloJin","6-2: DOWN!")
mqttJalloJin6_2.sendCommand(ON)
tMqtt6 = createTimer(now.plusMillis(iDuration), [
logDebug("JalloJin","6-2: STOP!")
if(mqttJalloJin6_1.state == ON) mqttJalloJin6_1.sendCommand(OFF)
if(mqttJalloJin6_2.state == ON) mqttJalloJin6_2.sendCommand(OFF)
tMqtt6 = null
lMqtt6 = false
else if (!lMqtt6)
switch (receivedCommand) {
case UP: mqttJalloJin6_1.sendCommand(ON)
case DOWN:mqttJalloJin6_2.sendCommand(ON)
case STOP: {
Log file output regarding the rule:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘JalloJin6 2’: Could not cast NULL to java.lang.Number; line 38, column 66, length 25
[ERROR] [ui.internal.items.ItemUIRegistryImpl] - transformation throws exception [transformation=org.eclipse.smarthome.transform.jsonpath.internal.JSonPathTransformationService@1620c27, value=86 %]
[vent.ItemStateChangedEvent] - mqttJalloJin6state changed from 92 to 90
As in the configuration there is no reference to REGEX, you don’t need REGEX. Don’t use on=“ON” and off=“OFF” as parameters, as you don’t need them.
You are using the JSONPATH Transformation Service twice (once in the channel, second in the label of the linked item, that doesn’t make sense.
In question of the Error: The first error may emerge because JalloJin6.state isn’t of type Number (yet). You should test this before using it. (like receivedCommand)
2nd Error… maybe tele/JalloJin6/STATE has sometimes no vaild path to Wifi.RSSI (Payload changes from time to time)
After I had selected “50%” I see the following in the Log (it looks like a Number):
[ome.event.ItemCommandEvent] - Item ‘JalloJin6’ received command 50
Sitemap is:
Selection item=JalloJin6 mappings=[ 0="0%",25="25%",50="50%",75="75%",100="100%" ]
Like it says, you can’t do maths on an Item state that is NULL.
All openHAB Items start life with state NULL.
Something has to initialise them - binding reading a value from a device, perhaps.
Or, you might write your rule to deal with the NULL case by making an assumption about the start value.
@rossko57: do you can give me an example please? I’m a absolute beginner, I work with Openhab since October.
This might help
