I activated a Electrodragon sonoff Modul with Tasmota on it.
All ok can see and switch in basic UI but this device has two relays. I can see these in the Tasmota web UI, but in OH2 I only do have on switch.
There is also only one topic in Tasmota mqtt.
This is the switch I called it Relais1 and so it is working, but in the mqtt settings of the device there is only one topic, so how to separate, and get access to the second switch off that device?
