Hello again,
I have done the last things you mentioned but they sonoff isn’t seeing any messages published. If I subscribe to the topic in my MQTT viewer the messages also aren’t coming through.
Here’s my configuration files:
Projector.items -
Switch TVScreen
String TVScreenCommand { channel="mqtt:topic:mosquitto:genericthing:tvscreen" }
mqtt.things
mqtt:broker:mosquitto [ host="127.0.0.1",secure=false, username="openhab", password="habopen" ]
Bridge mqtt:broker:mosquitto [ host="localhost", secure=false, username="openhab", password="habopen" ]
Thing topic genericthing {
Channels:
Type string : tvscreen "TV Screen" [ commandTopic="tasmota/cmnd/sonoff-rfbridge/rfraw" ]
projector.rules
rule "TV Screen UP"
Item TVScreen received command ON
TVScreenCommand.sendCommand(transform("MAP", "sonoffrf.map", "up"))
rule "TV Screen DOWN"
Item TVScreen received command OFF
TVScreenCommand.sendCommand(transform("MAP", "sonoffrf.map", "down"))
createTimer(now.plusSeconds(5), [ |
TVScreenCommand.sendCommand(transform("MAP", "sonoffrf.map", "stop"))
default.sitemap
Switch item=TVScreen label="TV Screen UP" mappings=[ON="UP"]
Switch item=TVScreen label="TV Screen DOWN" mappings=[OFF="DOWN"]
The only thing I can think I had to input into your example config was the channel name. The channel name was the generic mqtt string thing from paper ui: mqtt:topic:mosquitto:genericthing:tvscreen
Any ideas why this might not be working?
the logs show the following
14:19:51.984 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TVScreen' received command ON
14:19:51.997 [INFO ] [smarthome.event.ItemStateChangedEvent] - TVScreen changed from OFF to ON
14:19:52.032 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TVScreenCommand' received command AAB03C04081374027600DC13BA381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A1929292929292A192A19292A192A19292955
14:19:52.038 [INFO ] [arthome.event.ItemStatePredictedEvent] - TVScreenCommand predicted to become AAB03C04081374027600DC13BA381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A1929292929292A192A19292A192A19292955
14:19:52.055 [INFO ] [smarthome.event.ItemStateChangedEvent] - TVScreenCommand changed from AAB03C0408137E026C00DC13A6381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A1929292929292A1A1A19292A192A192A1955 to AAB03C04081374027600DC13BA381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A1929292929292A192A19292A192A19292955
14:20:15.788 [INFO ] [smarthome.event.ItemStateChangedEvent] - Michael_iPhone changed from OFF to ON
14:20:15.801 [INFO ] [smarthome.event.ItemStateChangedEvent] - Michael_Response_Time changed from UNDEF to 22.0
14:21:20.843 [INFO ] [smarthome.event.ItemStateChangedEvent] - Michael_iPhone changed from ON to OFF
14:21:20.853 [INFO ] [smarthome.event.ItemStateChangedEvent] - Michael_Response_Time changed from 22.0 to UNDEF
14:21:26.327 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TVScreen' received command OFF
14:21:26.357 [INFO ] [smarthome.event.ItemStateChangedEvent] - TVScreen changed from ON to OFF
14:21:26.365 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TVScreenCommand' received command AAB03C0408136A027600DC13C4381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A192929292929292A1A19292A19292A1A1955
14:21:26.375 [INFO ] [arthome.event.ItemStatePredictedEvent] - TVScreenCommand predicted to become AAB03C0408136A027600DC13C4381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A192929292929292A1A19292A19292A1A1955
14:21:26.383 [INFO ] [smarthome.event.ItemStateChangedEvent] - TVScreenCommand changed from AAB03C04081374027600DC13BA381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A1929292929292A192A19292A192A19292955 to AAB03C0408136A027600DC13C4381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A192929292929292A1A19292A19292A1A1955
14:21:31.376 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TVScreenCommand' received command AAB03C0408137E026C00DC13A6381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A1929292929292A1A1A19292A192A192A1955
14:21:31.385 [INFO ] [arthome.event.ItemStatePredictedEvent] - TVScreenCommand predicted to become AAB03C0408137E026C00DC13A6381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A1929292929292A1A1A19292A192A192A1955
14:21:31.395 [INFO ] [smarthome.event.ItemStateChangedEvent] - TVScreenCommand changed from AAB03C0408136A027600DC13C4381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A192929292929292A1A19292A19292A1A1955 to AAB03C0408137E026C00DC13A6381929292929292929292929292929292929292A192A1A1A1A192A1A1929292A1A1929292929292A1A1A19292A192A192A1955
