[SOLVED] sport.upnp.internal.UpnpIOServiceImpl Error - Sonos after todays snapshot
Haven’t upgraded since about a month. Now I get these exceptions, for each sonos device, it seams;
18:23:15.243 [ERROR] [sport.upnp.internal.UpnpIOServiceImpl] - Participant threw an exception onValueReceived
java.lang.IllegalArgumentException: Channel with ID 'tuneinstationid' does not exists.
        at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.isLinked(BaseThingHandler.java:609) [116:org.eclipse.smarthome.core.thing:0.9.0.201712011551]
        at org.eclipse.smarthome.binding.sonos.internal.handler.ZonePlayerHandler.updateChannel(ZonePlayerHandler.java:568) [208:org.eclipse.smarthome.binding.sonos:0.9.0.201712011551]
        at org.eclipse.smarthome.binding.sonos.internal.handler.ZonePlayerHandler.onValueReceived(ZonePlayerHandler.java:521) [208:org.eclipse.smarthome.binding.sonos:0.9.0.201712011551]
        at org.eclipse.smarthome.binding.sonos.internal.handler.ZonePlayerHandler.updateMediaInformation(ZonePlayerHandler.java:1069) [208:org.eclipse.smarthome.binding.sonos:0.9.0.201712011551]
        at org.eclipse.smarthome.binding.sonos.internal.handler.ZonePlayerHandler.onValueReceived(ZonePlayerHandler.java:445) [208:org.eclipse.smarthome.binding.sonos:0.9.0.201712011551]
        at org.eclipse.smarthome.io.transport.upnp.internal.UpnpIOServiceImpl$UpnpSubscriptionCallback.eventReceived(UpnpIOServiceImpl.java:158) [211:org.eclipse.smarthome.io.transport.upnp:0.9.0.201712011551]
        at org.jupnp.controlpoint.SubscriptionCallback$2.eventReceived(SubscriptionCallback.java:222) [185:org.jupnp:2.3.0]
        at org.jupnp.model.gena.RemoteGENASubscription.receive(RemoteGENASubscription.java:114) [185:org.jupnp:2.3.0]
        at org.jupnp.protocol.sync.ReceivingEvent$2.run(ReceivingEvent.java:130) [185:org.jupnp:2.3.0]
18:23:15.252 [ERROR] [rg.jupnp.protocol.sync.ReceivingEvent] - Invalid subscription ID, no active subscription: (IncomingEventRequestMessage) NOTIFY /upnpcallback/dev/RINCON_000E5810AFA601400_MR/svc/upnp-org/AVTransport/event/cb SEQUENCE: 0
18:23:15.251 [ERROR] [sport.upnp.internal.UpnpIOServiceImpl] - Participant threw an exception onValueReceived
I have Play5, Connect 80 and 100 devices.
This is a new channel, you have to re-create your Sonos things.
Thanks, that was indeed the solution!
