SOLVED : Squeezebox Binding+openhabian1.7 :Playtime conversion to minute and seconds not working
  • Platform information:
    • RPiB 4GB_
    • OS: openhabianv1.7 (Bullseye)
    • Java Runtime Environment:
    • openHAB version: V3.2
Have squeezboxbinding running with textual configuration and used following item:
Number:Time  SqueezeWintergartenCurrPlaytime      "Playing Time [JS(mmss.js):%s]"
Put the transform script in the …config/transform folder and as nothing happend and Dan Demento recommended maybe right problem i found the following:
transform
So i changed the rights for the 2 files i have created from openhabian:openhab to openhab:openhab
But nothing change; In the Main UI i still see always the Playing time only in seconds.
I am happy to get hints about this
The content of the mmss.js is:
(function(i){
    var s = ~~(i%60);
    return (~~(i/60) + ':' + ((s < 10) ? '0' : '') + s);
})(input)
Karl
Main UI does not use the Label in this way. Instead, you have to use Metadata
stateDescription=""[pattern="JS(mmss.js):%s"]
this is an additional part in {} , right after channel="...", so it would look like
Number:Time  SqueezeWintergartenCurrPlaytime      "Playing Time" {channel="...", stateDescription=""[pattern="JS(mmss.js):%s"]}
Great Thanks a lot
Testet it in the Main Ui directly
Shows now Minutes:Seconds :grinning:
Karl
