Transcend SSD370S interne SSD 32GB (6,4 cm (2,5 Zoll), SATA III, MLC)
Hi everyone,
i moved root to an external ssd.
My problem is that the ssd is in action all the time.
The Idicator LED is busy alle the time. This might be not healthy.
The System ist stable. No Problems.
Any ideas?
Did you ever change logging levels? Run log:get in Karaf to see what the levels are set to. You could also run something like this to see which files have recently been changed (just change to the current time and the correct folder for your install)…
ls -alR /opt/openhab2|grep "Mar 23 12:08"
Other than log files, I see a lot of writes to resolver-status.properties and org.eclipse.smarthome.core.thing.Thing.json. I’m running 2.3.0 snapshot 1238 though.
Meanwhile my Router (fritzbox) has crashed. Ive got another Router (different fritzbox) now without Internet connection. Openhab is runnig only in the LAN. The ssd is now less aktive. Maybe its the taffic to the Cloud connector or ifttt. I will check it when my Router is back using whireshark.
Can you reproduce this?
