When ssh openhabian@openhab, this is what is displayed:
chrx:~$ ssh openhabian@openhab
Linux openhab 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Oct 9 20:47:32 2019 from 192.168.22.54
2019-10-10 16:39:37,052: FireMotD: Info: Action "theme"
mv: cannot move '/tmp/tmp.WexrpkU63G' to '/usr/share/firemotd/data/FireMotD.json': Permission denied
chmod: changing permissions of '/usr/share/firemotd/data/FireMotD.json': Operation not permitted
mv: cannot move '/tmp/tmp.7kPYpkhlgS' to '/usr/share/firemotd/data/FireMotD.json': Permission denied
mv: cannot move '/tmp/tmp.Q2tfo4SocF' to '/usr/share/firemotd/data/FireMotD.json': Permission denied
mv: cannot move '/tmp/tmp.iFjYUvR0is' to '/usr/share/firemotd/data/FireMotD.json': Permission denied
mv: cannot move '/tmp/tmp.Sdp9D32Mta' to '/usr/share/firemotd/data/FireMotD.json': Permission denied
mv: cannot move '/tmp/tmp.FLaFRpKC5w' to '/usr/share/firemotd/data/FireMotD.json': Permission denied
mv: cannot move '/tmp/tmp.RYoVuUcAnl' to '/usr/share/firemotd/data/FireMotD.json': Permission denied
mv: cannot move '/tmp/tmp.gchGdKvAlo' to '/usr/share/firemotd/data/FireMotD.json': Permission denied
############### openhab #####################################################
## Ip = 192.168.22.15
## Release = Raspbian GNU/Linux 10 (buster)
## Kernel = Linux 4.19.66-v7+
## Platform = Raspberry Pi 3 Model B Rev 1.2
## Uptime = 0 day(s). 2:21:45
## CPU Usage = 1.52% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.39, 5m: 0.26, 15m: 0.17
## Memory = Free: 0.04GB (5%), Used: 0.90GB (95%), Total: 0.95GB
## Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
## Root = Free: 25.08GB (90%), Used: 2.69GB (10%), Total: 28.99GB
## Updates = 0 apt updates available.
## Sessions = 1 session(s)
## Processes = 123 running processes of 32768 maximum processes
Welcome to __ _____ ____ _
____ ____ ___ ____ / / / / | / __ )(_)___ _____
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ / / __ `/ __ \
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ / / /_/ / / / /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/_/\__,_/_/ /_/
/_/
openHAB 2.4.0-1 (Release Build)
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://openhab:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
[16:39:41] openhabian@openhab:~$
This happens even after a ‘fix permissions’ in openhabian-config
here are the ls -la
[16:51:55] openhabian@openhab:~$ ls -la /usr/share/firemotd/data
total 12
drwxr-xr-x 2 root root 4096 Oct 10 05:58 .
drwxr-xr-x 6 root root 4096 Oct 8 23:29 ..
-rwxrw-rw- 1 root root 3073 Oct 10 16:39 FireMotD.json
[16:52:16] openhabian@openhab:~$ ls -la /usr/share/firemotd
total 24
drwxr-xr-x 112 1001 1001 4096 Oct 9 16:32 ..
drwxr-xr-x 2 root root 4096 Oct 9 11:04 cache
drwxr-xr-x 2 root root 4096 Oct 10 05:58 data
drwxr-xr-x 2 root root 4096 Oct 8 23:30 templates
drwxr-xr-x 2 root root 4096 Oct 9 11:03 themes
[16:52:35] openhabian@openhab:~$
which I see is root:root. Shouldn’t it be openhabian:openhabian? or openhabian:openhab? or root:openhabian? or some other iteration?
if so, should this correction be in the ‘fix permissions’? (not a criticism, just a question)
