Hi there,
Is it possible to get a string from the http in order to get the following info?
Something like:
String Raw {http="http://192.168.2.135/cm?cmnd=STATUS"}
I do not get that it works…
Hi there,
Something like:
Have you worked with refreshintervalinmilliseconds or Command?
What value does the item have?
val String response = sendHttpGetRequest("http://192.168.2.135/cm?cmnd=STATUS")
But this is from a Sononf with tasmota firmware.
Have you heard of MQTT?
Yes, I know.
But I would like to get the POWER from http.
I want to pass this string:
{"POWER":"OFF"}
I have this rule:
rule "Power Rele"
when Item sonoff06 changed to ON
String estado "estado" { http="<[http://192.168.2.135/cm?cmnd=status/power]" }
logInfo("rule","Estado " + estado)
OK, it works.
Now I want to extract the field Power as a Number… to work with other rules
2018-07-12 15:22:11.613 [INFO ] [.eclipse.smarthome.model.script.rule] - Estado {"Status":{"Module":1,"FriendlyName":["Sonoff06"],"Topic":"sonoff06","ButtonTopic":"0","Power":1,"PowerOnState":3,"LedState":1,"SaveData":1,"SaveState":1,"ButtonRetain":0,"PowerRetain":0}}
val String sonoffStatus = transform("JSONPATH", "$.POWER", response }
Thank you!!!
