I’m using (since a while now) a rule to control our HVAC.
In this rule, i’m using House_Mode to check what must done (home, away, holiday…).
When I now set these values through the sitemap, it works great.
I now just introduce an automaticlly update through a rule (triggerd by a switch).
This works (for lights, audio…), and I see in my logs that the status is updated.
But my HVAC rule doesn’t notice the changes.
Any idea what I’m doing wrong?
else if (Heating_Mode.state.toString == "Werk") {
The rule that update the Heating_Mode, but the rule above doesn’t take it into account?
Item GebouwVerlaten received update
logInfo("SCENARIO", "Gebouw wordt verlaten")
sendCommand(Sonos_Controller, PAUSE)
sendCommand(TeRuMan, OFF)
Heating_Mode.postUpdate("Afwezig")
Same result. But maybe a stranger finding?
‘UIT’ and ‘work’ looks like working. But ‘Afwezig’ not?
A bit more details about the rule:
Item SCH_BURO1_TEMP changed
if (Heating_Mode.state.toString == "Uit") { //Zorgt ervoor dat alles UIT (en UIT) is
logInfo("HVAC_Bureel", "Geen verdere actie, de HVAC-Modus is: " + Heating_Mode.state + ".")
if ((((Bureau_TargetTemp.state as DecimalType))>(SCH_BURO1_TEMP.state as DecimalType)+1) && (Temperature.state < 20)) {
//De echte temperatuur is lager dan de gewenste, en buiten is het kouder dan 20 graden, dus verwarming aan.
logInfo("HVAC_Bureel", "Verwarming aan, de HVAC-Modus is: " + Heating_Mode.state + ".")
logInfo("HVAC_Bureel", "De temperatuur is lager dan gewenst [" + SCH_BURO1_TEMP.state + " < " + Bureau_TargetTemp.state as DecimalType +"]")
HVAC_BureelVerwarming.sendCommand(ON)
logInfo("HVAC_Bureel", "De verwarming is opgezet naar " + Bureau_TargetTemp.state)
if ((SCH_BURO1_TEMP.state as DecimalType).floatValue > ((Bureau_TargetTemp.state as DecimalType).floatValue - 0.3) &&
(SCH_BURO1_TEMP.state as DecimalType).floatValue < ((Bureau_TargetTemp.state as DecimalType).floatValue + 0.3)) {
logInfo("HVAC_Bureel", "Verwarming en arico uit, de HVAC-Modus is: " + Heating_Mode.state + ".")
logInfo("HVAC_Bureel", "Gewenste temperatuur is bereikt [" + SCH_BURO1_TEMP.state + " ~ " + Bureau_TargetTemp.state as DecimalType +"]")
sendCommand( HVAC_BureelVerwarming, OFF )
sendCommand( HVAC_BureelKoeling, OFF)
logInfo("HVAC_Bureel", "De verwarming & Airco zijn uitgezet")
if ((((SCH_BURO1_TEMP.state as DecimalType))>(Bureau_TargetTemp.state as DecimalType)+1) && (Temperature.state > 20)) {
logInfo("HVAC_Bureel", "Airco aan, de HVAC-Modus is: " + Heating_Mode.state + ".")
logInfo("HVAC_Bureel", "De temperatuur is hoger dan gewenst [" + SCH_BURO1_TEMP.state + " > " + Bureau_TargetTemp.state as DecimalType +"]")
HVAC_BureelKoeling.sendCommand(ON)
logInfo("HVAC_Bureel", "De Airco is aangezet naar " + Bureau_TargetTemp.state)
else if (Heating_Mode.state.toString == "Afwezig") {
Glad to hear you’ve made some progress in tracking down the source of your problem, Ben. If you need more assistance, don’t hesitate to ask for more help here. Please do post your findings when you have found and fixed the problem so someone else with a similar problem can learn from your experience.
