I’ve been working with OH for about a week and all was well until yesterday I noticed I couldn’t connect to my.oopenhab.org and reach my install. I started looking at the log file and noticed that it was complaining about not being able to read my openhab.cfg. It’s very odd as I’ve been editing this file for days and suddenly I’m getting this error. I checked the permissions on the file and opened the file by copy/paste the path listed below into my texteditor (Notepad++). I’ve also tried encoding the file in dos and unix format . The file is definitely there but for whatever reason it’s saying it can’t find it. I just don’t understand. This was working great now suddenly this:
07:57:33.247 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file ‘C:\openhab\configurations\openhab_default.cfg’.
07:57:33.251 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file ‘C:\openhab\configurations\openhab.cfg’.
07:57:33.381 [ERROR] [o.config.core.ConfigDispatcher:174 ] - Main openHAB configuration file ‘configurations/openhab.cfg’ cannot be read.
java.io.IOException: The system cannot find the path specified
at java.io.WinNTFileSystem.createFileExclusively(Native Method) ~[na:1.8.0_60]
at java.io.File.createNewFile(File.java:1012) ~[na:1.8.0_60]
at org.eclipse.equinox.internal.cm.ConfigurationStore.writeConfigurationFile(ConfigurationStore.java:112) ~[na:na]
at org.eclipse.equinox.internal.cm.ConfigurationStore$1.run(ConfigurationStore.java:99) ~[na:na]
at java.security.AccessController.doPrivileged(Native Method) [na:1.8.0_60]
at org.eclipse.equinox.internal.cm.ConfigurationStore.saveConfiguration(ConfigurationStore.java:97) ~[na:na]
at org.eclipse.equinox.internal.cm.ConfigurationImpl.update(ConfigurationImpl.java:255) ~[na:na]
at org.openhab.config.core.ConfigDispatcher.processConfigFile(ConfigDispatcher.java:212) [org.openhab.config.core_1.8.3.jar:na]
at org.openhab.config.core.ConfigDispatcher.initializeMainConfiguration(ConfigDispatcher.java:169) [org.openhab.config.core_1.8.3.jar:na]
at org.openhab.config.core.ConfigDispatcher.initializeBundleConfigurations(ConfigDispatcher.java:139) [org.openhab.config.core_1.8.3.jar:na]
at org.openhab.config.core.ConfigDispatcher.activate(ConfigDispatcher.java:99) [org.openhab.config.core_1.8.3.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_60]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_60]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_60]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_60]
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:141) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:139) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.equinox.internal.cm.ManagedServiceTracker.addingService(ManagedServiceTracker.java:65) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:932) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:894) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:536) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:260) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_60]
Does anyone have a clue as to what’s going on? Thanks!
