[SOLVED] Sum up and multiply item values at startup
As mentionned before
Please follow the rules tutorial:
https://www.openhab.org/docs/tutorial/rules.html
Follow @rossko57 advice above
and you should end up with something like this
Notice the use of the code fences
rule “INIT”
    System started
    // Set WWALARM to off = 0
    WWALARM.sendCommand(OFF)
    // Calc PWWSUMME & PHEIZENSUMME
    var Number num1 = PWWSUMME1.state as Number
    var Number num2 = PWWSUMME2.state as Number
    var Number num3 = (num2 * 1000 + num1)
    PWWSUMME.postUpdate(num3)
